Engine Fan Staying On
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by KWP_15, Jul 28, 2020.
  1. KWP_15
    KWP_15 Bobtail Member
    17
    15
    Mar 8, 2019
    I have a 2018 Kenworth t680, and the engine fan is acting unusual. It is staying on longer at times, even when the indicator light turns off. It acts normal sometimes, but then at times it has a hard time turning off. The truck does have some sort of air leak currently. What can the issue be? Where is the solenoid located? What should I check for?
    Thanks!
  3. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,163
    Jun 3, 2018
    Does it only stay on when the A/C is On? Could be a pressure switch.
    QUALITYTRUCK Thanks this.
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    What kind of air pressure problem are you having? The fans are designed to lock on when secondary air drops below 50psi.
  5. KWP_15
    17
    15
    Mar 8, 2019
    I haven't tested the connection with ac. I will try turning it off, and seeing if there's any difference.
  6. KWP_15
    17
    15
    Mar 8, 2019
    I'm just losing air when parked overnight. It doesn't loose pressure while driving.
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    You have probably inadvertently solved your own problem. Removing air from clutch engages fan. Conversely, applying air disengages it. Build truck air to 120 psi, turn truck off, count to 10, turn key on. Fan should disengage without any air leaking from clutch or air line going to it. If no leak, report back for further troubleshooting help.
    Rideandrepair Thanks this.
  8. KWP_15
    17
    15
    Mar 8, 2019
    It doesn't really stay on when I start it up in morning. It's more like at random times during day while driving. The indicator light for fan turns off, but fan keeps running for 5-10min.
  9. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Probably good thats it's staying on. It's been over 100 degrees outside.
  10. KWP_15
    17
    15
    Mar 8, 2019
    I've been testing it today, and it has something to do with the ac. When I turn the ac off, it turns off in a bit. Something with the ac, causing it to stay on..
  11. Concorde
    Concorde Road Train Member
    5,471
    19,369
    Jun 29, 2016
    West Melbourne Florida
    Fan solenoid is failing..soon it will just stay on.
    I just went through it with my 2014 t680
    if you want a picture of the location I will upload one.
    Rideandrepair and KWP_15 Thank this.
