engine idle speed doesn't work
Discussion in 'Freightliner Forum' started by porema, Sep 13, 2011.
  1. porema
    porema Bobtail Member
    Have a 2005 Century and was able to regulate the engine idle speed while parked. Las winter had to run throught heavy snow on the interstate and now not able to regulate the idle. But cruise control works fine and engine doesn't stall at idle. Any ideas ??
  3. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    check the hobbs switch in your dash as it might be mounted on an air manifold with other air switches [like brake light sw]. see if it works when you pull park brake buttons.the switch prolly is ng as it's not completeing elec circuit.
