Engine light on,both of them .
Discussion in 'Experienced Truckers' Advice' started by bully1724, May 30, 2016.
  1. bully1724
    bully1724 Bobtail Member
    Hello.after taking my 2012 freightliner cascadia in to do all the bushings front and back and alignment I got all kinds of engine codes .it reads engine 2 spn 000636 position sensor 3,8,11,15 the mechanic said it happens when they lift the truck .but they haven gone away I clears and they still come back .both check engine lights are still on wont turn off.can anyone help out.
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    How far from the mechanic are you. Can he hook up a laptop and clear the code.
    If not. Disconnect the negative battery terminals for a couple minutes, at least 30 seconds. See if this will clear the code. There may be a way to key on without starting truck that may help also, not sure.
    I'm just guessing. I don't have your type of truck.
    Call a Freightliner dealer
    Good luck.
  4. bully1724
    Thanks for the reply .I'll try that .my truck seems to b running fine exept when I try to start it.it trys to start for a couple of seconds and I have to hold egnition on for like 2 sec .it never did that bfor .thanks for the advice.b safe
  5. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Freightliners usually have a 'nighttime' switch in the cab, so you can disconnect power without having to get into the battery compartment.
  6. xsetra
    5,195
    7,146
    Aug 21, 2011
    I have a 99 FLD120 . Where might this ,nighttime, switch be.
  7. bigmotor1212
    bigmotor1212 Light Load Member
    256
    363
    Dec 20, 2014
    Yours doesn't have it. They only put those in for a few years, they've stopped now, or at least they don't put them in every model. I don't think they shutdown the primary ECM anyway.
  8. GenericUserName
    GenericUserName Road Train Member
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    Honestly probably reflects badly on my part but i mostly ignore check engine lights on crapcadias. Ive had 3 of those pieces of garbage- 2015 70k miles, and 2 brand new 2016 9k and 2016 1200 miles. All three of them constantly have the check engine light coming on. Im not spending all of my working hours in the shop. I dont get paid for that.
    bigmotor1212 Thanks this.
  9. Getsinyourblood
    Getsinyourblood Road Train Member
    1,274
    1,810
    Jul 5, 2014
    Retired. North Texas
    That switch, if you have one, will be on the floorboard on the left side of the drivers seat. You can turn if off for 5 minutes, then back on. If your lucky, that may clear the codes.
  10. austinmike
    136,039
    Last time that happened on my 2010 it threw a egr fault code. I jiggled the rod connected to the egr and the lites went off.
    I have cleared em by turning off that master switch mentioned above also. Good luck.
  11. WitchingHour
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Yeah, it's a feature on more current models. It's basically a master disconnect, so, if you wanted to install one, you could do it quite easily.
