Engine Locked Need Help
Discussion in 'Freightliner Forum' started by AFC, Aug 3, 2024.
  1. Oxbow
    Oxbow Road Train Member
    13,735
    142,517
    Nov 24, 2015
    Also, not that it matters, why were you pulling off in the first?
  3. AFC
    AFC Heavy Load Member
    889
    1,177
    Jan 1, 2024
    I’m still making payments on the truck so I don’t have the title. The insurance is the companies insurance. As you know anyone that doesn’t have their own authority has to go with their carriers insurance
    Oxbow Thanks this.
  4. AFC
    889
    1,177
    Jan 1, 2024
    Checking on the load and I had Beacon lights on the oversize load and wanted to make sure they were secure them in a different position on top of the load instead of on the side of the load that way oncoming traffic could see them better
    Oxbow and Siinman Thank this.
  5. Lane=addict
    Lane=addict Light Load Member
    147
    163
    Aug 12, 2024
    Earth
    Good deal when I paid $700 for 1 miles in York Nebraska in winter to thaw a frozen engine.
    Oxbow Thanks this.
  6. Rideandrepair
    17,583
    56,953
    Aug 8, 2015
    Insurance will cover hitting a deer. You must have a lease purchase agreement with the Carrier. Explains a lot. Typically an O/O leased onto a Carrier is covered under their Public Liability and Cargo. Collision Fire Theft is optional coverage for the Vehicle itself, and usually in the Owners name. In this case, they still Own the Truck. Might consider walking away from the whole mess, instead of owing thousands of dollars just to keep operating. It’s not your Truck.
    TheLoadOut and ElmerFudpucker Thank this.
  7. AFC
    889
    1,177
    Jan 1, 2024
    I do have physical damage insurance through the carrier. I don’t want to walk away as I only owe 35,000 left on this truck. My monthly payments are reasonable 2500 a month I own the trailer but After this incident and basically not working for 2 to 3 weeks. I’m not in a financial position to buy another truck, I hope the insurance doesn’t do a total loss and I hope to get reimbursed by the insurance for the tow truck and some of the other repairs. The deductible is $2500.
    Rideandrepair Thanks this.
  8. Ridgeline
    22,776
    124,542
    You are assuming he was running hard and hit the object then went on for hundreds of feet under a load.
    I don't think insurance is going to cover anything, I don't think the engine is seized, it may be a case as I pointed out of other issues - electrical.
    But it also isn't his truck, it is the company's truck, which means he doesn't have a lot of say in it, he isn't a legal owner of the truck, and they can just give him another truck and tell him too bad.
    I don't think any of the mechanics knew a **** thing about troubleshooting the problem, I think they assumed that the driver was the one who was on top of the problem. As you mentioned they screwed the driver and this is why I am thinking that unless it is pulled apart to see exactly what happened after the look at the starter and electrical system (still thinking it is a starter issue, not a bearing issue), then we would know. But again it is all up to the company, they most likely will write it off as a loss when they toss an engine (or starter) into it and go from there.
  9. wore out
    wore out Numbered Classic
    17,545
    219,215
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I had never given the slow speed any thought. You make a good point
  10. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    I think this is a modern day mechanic issue. Any old farm kid would be able to bar over an engine then jump a starter if needed. Some guys think plugging a cable and laptop into a truck is the only way to find the problem, it sure can help, but it's certainly not the only way to diagnose a problem.
    That engine may have turned over easily with a breaker bar, may have turned over fine by jumping the starter solenoid and even shown normal oil pressure while doing so.
    Basic hand tools and a volt meter can save a guy a fortune.
  11. Antinomian
    Antinomian Road Train Member
    2,193
    3,492
    Feb 17, 2013
    Why isn't the oil pan off already? It has a hole in it. It's been a week.
    Rideandrepair and Oxbow Thank this.
