Engine oil consumption
Discussion in 'Experienced Truckers' Advice' started by Mandeepsingh, Jun 15, 2019.
  1. Mandeepsingh
    Mandeepsingh Light Load Member
    63
    23
    Aug 30, 2018
    But like i said i m adding 1 or 2 quarts within 2000-2500 miles. That’s normal right? Without any leaks
  3. jamespmack
    216,477
    Ok couple ideas. 1. Don't top it off till it hits the low level. See if it stabilizes. You may find it levels off and stops going down. 2. look for obvious leaks. 3. Consider a different brand of oil, and maybe shorting your oil change intervals. I don't care what anyone or Cummins tells you. I would change a ISX at 15k miles and no longer. Personally I would do 10k but thats my weird way. Oil and grease will be the cheapest things you ever buy. 4. inspect turbo for oil leaking out exhaust.
    TGUNKEL, Dan.S, magoo68 and 3 others Thank this.
  4. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    ####, why so angry. gee wiz
    bzinger, Lepton1 and frito bandito Thank this.
  5. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    No, that's not normal. In 15000 miles that's 2 or three gallons. Way too much. Try what James recommended above, if it's still using oil, you need to visit an engine shop and find out why.
    Dan.S, Lepton1 and jamespmack Thank this.
  6. mitrucker
    mitrucker Road Train Member
    5,476
    10,281
    Dec 15, 2010
    Lapeer, MI
    I drove one that used a gallon every 1500-2000 miles. Ryder said that according to Cummins, that was normal oil consumption.
    86scotty and QuietStorm Thank this.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    ISX motors only like mobil1 or delo400. Mine had a sticker on the frame that said only mobil 1. And that sticker did not lie.
    You'd be amazed at oil consumption between top tier and crappy oils. Crappy oil also causes gasket leaks.
    Dan.S and Lepton1 Thank this.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You isx probably has carbon packing up on the rings. It will just get worse and worse. It is a known issue with those engines. Start saving for a inframe.
  9. jamespmack
    216,477
    I don't own a Isx and don't plan on it. I have worked on a few. But I might give this a try in the engine oil, and the fuel. Been since 1946. While its not a store brand it works on alot of applications. Its worth a shot. Carry extra fuel filters. 23-138x206.jpg
  10. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Those poor motors are choked to death, I like them though, if you do an inframe do a delete, she'll run a lot better and you won't have to buy def.
  11. Cam Roberts
    1,621
    1,938
    May 13, 2018
    big 10-4. i know of noone that keeps any emissions crap on their motor after their first overhaul. It would be just assinine and poor if they did
    Tombstone69 and jamespmack Thank this.
