Engine oil dye
Discussion in 'Ask An Owner Operator' started by pavrom, Jul 26, 2021.
  1. pavrom
    pavrom Road Train Member
    3,214
    7,400
    Apr 29, 2012
    NE illinois
    I am planning to clean my engine and add some dye to detect all possible leaks . Is it a good idea ?! Any dye will work for this ( i mean engine oil dye , i asked my mechanic whos servicing my regular cars to order some for me ...not sure if there is a difference between diesel and gasoline engine dye ).
  3. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Do you have oil leaks for something?
    feldsforever and Rideandrepair Thank this.
  4. pavrom
    3,214
    7,400
    Apr 29, 2012
    NE illinois
    I have leak under head ...
    Rideandrepair Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Seek a doctor not mechanic
  6. Rideandrepair
    17,531
    56,813
    Aug 8, 2015
    Power wash it, and run it a bit. Throw some talcum powder at it.
    Big Road Skateboard Thanks this.
  7. Big Road Skateboard
    7,034
    39,819
    May 2, 2021
    If you already know where the leak is, what good would dye do you?
    27 years experience here as mechanic, and I've never needed to dye oil to find a leak. Hell, I've never even heard it suggested.
  8. Big Road Skateboard
    7,034
    39,819
    May 2, 2021
    Yep. Been working for years.
  9. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    No difference between diesel and gas oil dye. If a DD15 common oil leak is around rocker box
  10. 201
    201 Road Train Member
    12,736
    26,193
    Apr 16, 2014
    high plains colorado
    Mmm-hmm, I can hear it now down the road,,,"yep, here's your bearing failure cause, engine dye,,,we see this a lot",,, for all we know, the "dye guys" sell reman motors. I've heard of black light dye in the coolant, as those leaks are harder to spot, but an oil leak should be pretty obvious. Sounds like a head gasket, and poor pavrom troubles continue, "it's a always a somethin",,
  11. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Isnt that just the reality of any o/o ?
    feldsforever and 201 Thank this.
