engine pushing water
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mike91118, Jun 30, 2012.
  1. mike91118
    mike91118 Medium Load Member
    373
    32
    Feb 9, 2010
    clarksville,tennessee
    what do i do if the engine is pushing water cause my cousin truck is doing that
  3. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Drive it out of the pond ??????????????????
  4. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    If your refering to pushing coolant. Out of overflow could be injector cup o rings or headgasket. Or maybe cracked liner, head, or block.
  5. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Or depending on what kind of truck it is it could be as simple as a air/electric valve for the heater causing this.
  6. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Or the compressor head gasket is gone.
  7. mike91118
    373
    32
    Feb 9, 2010
    its a 2005 kenworth t2000
    he thinks someone put water in his tanks
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,734
    Jan 30, 2010
    keep stroking.
    Put water in his tanks? if your talking about fuel tanks then no. but it wont push water out of them. if your talking about radiator cap,then water in the fuel tanks isnt going to do that.it will just wont run until you drain the water and put new fuel filters on.
  9. Poor boy
    Poor boy Bobtail Member
    49
    43
    Feb 10, 2011
    Kansas
    You really need to give a lot more info to even come close to getting an answer for your question. Where is the water? Any other symptoms? what motor and truck is this in?
  10. Poor boy
    49
    43
    Feb 10, 2011
    Kansas
    Sorry you did say what truck but not motor type.
  11. 59BROCKWAY
    59BROCKWAY Light Load Member
    168
    68
    Jun 22, 2012
    Northeast
    Depending upon age of truck and engine , liners can become porous , in a sense they look like swiss cheese or termite holes , could be a head gasket too . I'd say if its your bread and butter , get it fixed before it really fixes you at an inopportune time on the side of the road or the middle of the road.
