Engine question!!!
Discussion in 'Ask An Owner Operator' started by Barbeque, May 14, 2019.
  1. Barbeque
    Barbeque Light Load Member
    199
    309
    Aug 25, 2015
    Everywhere USA
    What year did Cummins stop putting the manual water shut off valve on. If you’re not getting what I’m asking about? It’s the hand valve you turn for heat in the winter.
  3. Ridgeline
    22,685
    121,664
    What?
    I have 2019 with hot water valves on them, they are ball valves and factory as factory can get.
    Intothesunset Thanks this.
  4. Tug Toy
    Tug Toy Road Train Member
    7,028
    73,657
    Jul 4, 2015
    Corn field
    I’m sure it’s in the spec of each truck. My 2001 ISX had gate valves on it. I replaced them a couple years ago with 1/4 turn ball valves.
    I’d guess the gate valves were original?
    Our company T680’s 2013 with ISX didn’t have them and the NEW paccar engines we just got don’t have them. I’m sure it’s the way they are ordered.
    Trucks today have better HVAC controls than back in the day so they are not as useful as they used to be. Plus the BTU’s of modern AC is huge compared to old.
  5. AModelCat
    162,928
    Its probably not so much engine specific as it is truck manufacturer specific.
    spsauerland Thanks this.
  6. Hammer1113
    Hammer1113 Light Load Member
    I don’t know hat they ever QUIT putting them on moreover making them optional. I can’t think of any reason you couldn’t put one on. All it would take is an in-line “T” fitting, and a ball valve. Well actually two of each, you would have to run one supply, and one return line.
  7. Powder Joints
    7,960
    8,324
    Sep 25, 2007
    Rosamond, SoCal
    Dang I thought those were for instant coffee...
    JoeyJunk Thanks this.
  8. GreenPete359
    GreenPete359 Road Train Member
    2,216
    5,291
    Oct 21, 2017
    Driving my recliner
    I think it’s all in the way the truck was ordered. I’ve driven Macks, Cats, & Cummins that were all hit or miss on whether or not the specific truck would have them.
  9. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Kinda like whatever the manufacturer had on hand at the time.
  10. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Some are plumbed in line with the def tank heat coil, they don't get shutoff valves because that would also stop the circulation through the def tank.
    If that is the case on your truck then you must separate the def tank lines from the heater core lines and install the ball valves after the split, you cannot just install them in the block port like the pre emission engines had.
    I put them on my PACCAR but I first replumbed it so the heater core was independent of the def tank plumbing so it would not throw a code related to the def temperature
  11. fortycalglock
    fortycalglock Road Train Member
    6,162
    6,604
    Jun 25, 2011
    Tourist Town, FL
    It’s already been answered obviously that it’s truck manufacturer and who ever orders dependent. Trucks with a modern HVAC with blend doors don’t really need the shut offs. A truck like my Western Star that still uses a HVAC system that always blows through both the heater core and the a/c evaporator still need them.
