Engine smoking not water
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Haulindave, Jul 23, 2014.
  1. Haulindave
    Haulindave Bobtail Member
    14
    Mar 8, 2013
    Just did a inframe on my cummins m11 . Had head done and remand injectors . Drove about 30 miles climbing hill and heard slite ticking from engine then smoke real bad , so bad someone call fire department . Pull over and had towed to my place . No water in oil , was dripping oil or diesel from turbo or both . My mechanic ( brother in law ) said he thinks it's a blown head gasket . Does this make any sense .
    Looking for advice not sure he knows what he's doing
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Haulindave Thanks this.
  4. Haulindave
    14
    Mar 8, 2013
    Can you explain better . Pull exhaust man . There is a main oil line going to turbo . Oil out of exhaust port ? Thanks I'm not a mechanic . So you think it's the turbo , is that what your saying .
    baha Thanks this.
  5. camaro7019
    camaro7019 Bobtail Member
    5
    Jul 23, 2014
    sounds like a broken injector tip, aslong as it is diesel out of the exhaust, would explain ticking, oil wouldn't explain ticking unless it broke a valve or something, most likely injector
  6. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    Sorry if you pull the ex. man. you can l see if one of the ex. ports are wet with fuel or oil, turbo will be wet with oil on intake side or ex. side you will find out before having to pull man. so best to start by pulling clamp at ex. side of turbo an look into ex.pipe with light for oil?
  7. Haulindave
    14
    Mar 8, 2013
    Well took engine apart till I new what happened and found number one cylinder basically seized even though the others were still moving it . Piston has scratch all up and down it . Rings look melted in . Oiler at bottom of cylinder bent and doesn't even look like oil was going though it or maybe not even though the hole that goes to it . My mechanic doesn't know what happened ? Hmmmm
    baha Thanks this.
  8. wore out
    wore out Numbered Classic
    17,297
    214,475
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I'm thinking careless pulling the liner, piston and rod out. Which is fine because after inspection that should have been seen when all six were replaced. Coulda happened going in but still no need in forcing. course I put my cooling nozzles in last. Not to stir the pot but the entire oiling system is full of metal now
    baha and Haulindave Thank this.
  9. Haulindave
    14
    Mar 8, 2013
    how can u clean the oiling system out .
  10. wore out
    17,297
    214,475
    Jun 5, 2013
    The right way is a complete teardown and vatt the block. At bare minimum I would pull the oil cooler and wash it out as well as all the piston cooling nozzles and flush the oil galley in the block. Any minute now someone is gonna say that's what filters are for. Well the filter is the last place oil goes before returning to the pan. Nothing puts metal in the pan like a galded piston.
  11. Haulindave
    14
    Mar 8, 2013
    My mechanic says he didn't break cooling nozzle when he took it out and says there is know way you can see if it's getting hit before running it . He says he put together right and takes no responsibly for its failure .
