Engine temp 170.
Discussion in 'Volvo Forum' started by Paul Chamberlin, Feb 17, 2020.
  1. Paul Chamberlin
    Paul Chamberlin Bobtail Member
    40
    20
    Aug 6, 2018
    Highway
    Volvo d13 2015
    Engine temp runs at 170 all the time, won’t move unless heavy on long grades.
    Had new thermostat put in and temp sensor tested, still runs cold.
    Anyone else have this issue or had this fixed?
  3. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Mine does the same thing, and I never thought 170 was cold.
  4. Paul Chamberlin
    40
    20
    Aug 6, 2018
    Highway
    Shop said normal was 185/190, mine used to run there and bump up at inclines or heavy street traffic. Now it’s at 170 all the time. As sensitive as these trucks are with emissions and tolerances I want to fix whatever the issue is b4 it breaks something expensive.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,140
    Mar 5, 2016
    White County, Arkansas
    Thats cold. I like mine at 190ish give or take.
  6. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
    You don't even have one! You overheated the one you had and burnt it up doing 100+! We know all about you!
    magoo68 and spyder7723 Thank this.
  7. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    My 2010 runs at 170 just cruisin. 170 is normal.
  8. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    170 is normal Volvo temp your truck is running where it’s supposed to be.
  9. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    My Volvos ran at 170°,had serious fans when pulling grades 100° outside. Up to 200° then right back down to 170. My current Freightliner is always at 195°.
    x1Heavy Thanks this.
  10. pittbull670
    pittbull670 Bobtail Member
    31
    8
    Dec 27, 2015
    Mine sit at 170 al the time ,goes over when going up hill and then goes down to 170 again.
  11. Paul Chamberlin
    40
    20
    Aug 6, 2018
    Highway
    I’m going by what the tech at Volvo said, should be around 190 deg.
    This truck does not run right and Volvo can’t find a problem. I’ve replaced everything on the emissions, egr valve, egr cooler, thermostat, cleaned dpf, cleaned scr (did notice the doser is over dosing def fluid) had overhead run, had cylinders tested. I’m in the hole big for January and it’s still not working right. About to give up, I can’t survive the remaining 12 months of payments at 6mpg.
