Enough Space?
Discussion in 'Experienced Truckers' Advice' started by rored23, Feb 3, 2021.
  1. rored23
    rored23 Bobtail Member
    Feb 3, 2021
    Hello and thank you for any help you can give.
    I'm a transportation manager and we're sourcing a new facility in SoCal. I have reservations on if there's enough room to function at a facility our DC director likes. We need to keep some 40' ocean containers on site.
    How much space would you need to pull out and/or back into a dock if hauling a 53 or a 40? Let's assume we could either have docks side by side (2-4' between) and/or only use every other dock, so 12-16' between each box.
    The yard in question is 105' from dock to fence and some folks here think we can store 40' along the fence line...
    Thank you for any help you can give.
  3. GoneButNotForgotten
    GoneButNotForgotten Heavy Load Member
    938
    1,872
    Dec 30, 2009
    Roxboro, N.C.
    That sleeper cab with a 53' attached is about 70 feet long. How much room does your guys think is needed to back in and pull out of a dock space? Maybe they can demonstrate.
    rored23 Thanks this.
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    If you park the container up against the fence you're going to lose 8-9 feet so that pushing that to 96-97 feet. Let's say you have a long nose KW or Pete coming in with a 53' trailer that's closer to 80'. I pulling into a spot that is pretty close to that area you are considering & those long nose fight to put it in & pull out. The space between the docks is about 2-3 feet when a truck is in the next dock.
  5. Bill51
    Bill51 Road Train Member
    1,185
    2,982
    Jul 27, 2015
    @rored23
    They are wrong. The drivers will stuggle with just the room you mention.
    And your idea of using every other door will disappear as fast as a triple chocolate cake at a weight watchers meeting.
    In fact, if there is an open door, with sleeper cab tractor trailers on the doors to either side, a sleeper cab tractor trailer will NOT be able to get into that open door.
    See if this url works (Columbia Distributing in Kent WA):
    Google Maps
    This has maybe a few feet less than what you are talking about (53' times 2 about). I had to wait for one of the trucks to pull out before I could get on the open door between them. Just not enough room.
    If you zoom in, you can see how that chain link fence gets bumped constantly.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Bout this much. I'm 71ft and my wheels don't cut 90° like most of these newer trucks
  7. GreenPete359
    GreenPete359 Road Train Member
    2,235
    5,361
    Oct 21, 2017
    Driving my recliner
    i see your hard dock & raise you RLB in West Caldwell,NJ... D78152C2-BEE8-4A80-AFA5-C7B647EC7291.png
    there is a brick retaining wall at the grass line across from the dock. Many hoods and bumpers have been lost in this place
    650cat425 and ibcalm19 Thank this.
  8. buzzarddriver
    3,812
    11,455
    Feb 1, 2011
    Dallas, TX
    Just remember, if a 53' or for that matter a 40' chassis is in a door, you would need another 75' to get another 53' in the door next to it. Another matter is: how far is it between doors? That will also have an effect on trailer swing. If you are going to have a bunch of containers sitting around, parking them in front of doors is going to cause headaches unless the fence is far away.
    ibcalm19 Thanks this.
  9. rored23
    Feb 3, 2021
    Thank you all! I've been doing this for a hot minute, but I've never actually had to explain with such detail exactly why there wasn't enough space - usually they trust me since, I've been doing this a hot minute. I provided the below to them. The 2 orange rectangles represent a 40' with a cab. Double it and all the space is gone - and forget a 53. *sigh*
    Dale thompson Thanks this.
  10. rored23
    Feb 3, 2021
    This was my favorite by the way.
    GoneButNotForgotten and 650cat425 Thank this.
  11. Motor Trucking
    Motor Trucking Bobtail Member
    19
    14
    Dec 5, 2018
