Failed Skill Test!!! Need advice
Discussion in 'Trucking Schools and CDL Training Forum' started by fueltanker99, Jan 10, 2019.
  1. fueltanker99
    fueltanker99 Bobtail Member
    30
    14
    Jan 10, 2019
    I was at knight Transportation Cdl school in Phoenix. I'm confident and strong on the driving I'm strong in everything except parallel parking. I failed twice on my road test on parallel. Knight wanted me to retest but I hate to use my third chance on that mistake. I'm from Tennessee I really couldn't find most places to rent a truck and test here.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    uh, go back for re-training/practice?
    that's the best advice i can give.
    brian991219 and Puppage Thank this.
  4. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Failed skill test? Advice?
    More practice.
    buddyd157 Thanks this.
  5. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Walmart needs some door greeters lol practice more
    IluvCATS and buddyd157 Thank this.
  6. bryan21384
    bryan21384 Road Train Member
    15,664
    34,100
    Sep 18, 2009
    Memphis, TN
    So......the guys pretty much already said it, but do you know where you are going wrong parallel parking?
  7. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    I was 45 and terrible at parallel parking. I set up cones and wood 4x4s and practiced it for like 8 hours total in a few days. That helped and I passed the first try.
  8. UturnGirl
    UturnGirl Road Train Member
    3,095
    13,517
    Jan 16, 2010
    Texas
    Parallel parking is a trick. Gotta have a system for setup and wheel turns. Last time I took drive test I drew the short straw and had to blind side parallel park. I just took a deep breath and trusted the system I had practiced.
    No actual cones were harmed in the process.
    IluvCATS and Dan.S Thank this.
  9. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    I practiced alley docking daily, did it beautifully every time on practice runs. Parallel is what really had me nervous, tended to be a hit or miss for me practicing. Go to take my test, absolutely butchered the alley dock when it actually counted. Went back a week later and they switched it up, had me do parallel instead of alley dock, I truly couldn't have knocked it out more perfectly. God bless my trainer
  10. brian991219
    brian991219 Road Train Member
    3,012
    6,155
    Aug 10, 2013
    Lords Valley, PA
    You only have one more shot, it doesn't matter if you take it at Knight or in Tennessee. Actually, you may have a better chance of passing if you try again in the same truck you have been practicing in. Going to a rental place will give you a different truck that may handle and shift different, resulting in you failing a different part of the skills test.
    Where ever you end up taking the test it is highly likely you will have to do at least one parallel park maneuver. Just practice and keep on going.
    ichudov Thanks this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If it is any assurance, I only had to park in that style twice and a third time was on a bet versus 8 meters. It is not a common skill. Nor was it required in Maryland back in the 80's
