False high pyro reading???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cattleman84, Oct 17, 2022.
  1. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    '07 W900, C15 475 Acert, twin turbos and turned up to 550 HP, 18 speed, 3:36 rears.
    Truck has been running really good lately pulling A-Train hoppers up to 142,500 gross... Usually about 110,000 though.
    Tonight headed home empty as I got off the interstate I noticed my pyro was sky high (about 1300) and red warning light on. Took it really easy for about 5 miles to a place to get pulled off the road c.ame down to about 1100... Anything above a high idle the pyros would climb back up.
    No discernable smoke by sight or smell. Let it cool to about 800 then shut it off, shut off clean... No dieseling. Counted to 20, turned key on and let guages do thier sweep, pyro settled on 850. Cranked up the engine, clean start, pyro immediately dropped to 350 and then came down to 300. Rolled the hood, no evidence of excessive heat (flex pipe behind turbo normal color, spit on flex pipe and it slowly evaporated) pyro sensor and wire intact. Acted fine the 20 remaining miles to home, even when I really leaned into it. Ive never seen this truck go over 1000 on the pyro, even when pulling hard and heavy.
    Dieing Sensor? Electrical gremlins?
    @AModelCat any thoughts?
  3. AModelCat
    164,322
    Sounds like a sensor issue. Maybe the wiring to the probe is rubbing on something?
  4. Cattleman84
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Kinda what I thought too. If wire is rubbing its deeper in than I wanted to dig on the side of the road... Its Definetally not laying down on the pipe or manifold that I could see.
    D.Tibbitt, singlescrewshaker and Oxbow Thank this.
  5. AModelCat
    164,322
    Wouldn't hurt to shoot the manifold and turbo to see if things match up or not.
  6. Oxbow
    Oxbow Road Train Member
    13,639
    141,346
    Nov 24, 2015
    Could just be time for a new probe?
  7. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    I had ISSPro aftermarket pyro temp kit installed on S60. After 5 years it dyed and before going bad it was doing this kind of things
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I just changed the pyrometer head in my ‘05 W900. It was reading almost 200* low, showing 1000* when it was actually running a little under 1200*. Thank #### it’s got steel pistons in it.
    singlescrewshaker and Cattleman84 Thank this.
  9. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    The sensor for a pyro is a thermopile. A thermopile is a battery that produces electricity when heated.
    The more heat the more electricity. Like all batteries it has a life expectancy.
    Oxbow Thanks this.
  10. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Thermocouple?
    Oxbow Thanks this.
  11. Oxbow
    13,639
    141,346
    Nov 24, 2015
    I've always known them as thermocouples too, but I had no idea how they actually worked.
    LameMule Thanks this.
