Fan running when temperature is normal.
Discussion in 'Freightliner Forum' started by dismag, May 26, 2014.
  1. dismag
    dismag Bobtail Member
    37
    Jul 20, 2012
    I have columbia 2005 D60 engine. Some times when temperature is normal fan just start running no fault codes. I do have some times check engine comes on with id156 fm0 but it is not happened when fun start running spontaneously. Does any body have an idea what can be the cause of the problem?Thanks
  3. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    A/C running will signal turn fan on when pressure gets high. Not a problem.
    Richter Thanks this.
  4. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    where wire harness comes out of rear harness of ecm,look for worn insulation on wires.pin v-4 is fan output wire.i will bet more than one wire is exposed,terrible design flaw with harness looping down.good luck.
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Is it only happening while a/c s on? batmick [​IMG] is right. I got an 06 and it turns on radomely but only if a/c is on in front or sleeper. Normaly it should come on a little over 200 unless you hit the over ride switch. If it is truely coming on not do to a/c....it could be anything from a leaky fan cluch to bad electronics to bad ecm. Could even be a bad override switch.
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    The fan will come on at whatever temperature it is programmed to come at. No specific temp.
    If it is coming on when the AC is off, check the solenoid and airlines first. Cheap part to replace, and very doable yourself. The solenoid could be hanging up.
    Also, does your fan spin freely when the engine is shut off, or does it lock up? Some need air to release, some need air to lock.
    Martin
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Also keep in mind that the A/C will cycle with the defrosters on, even if the A/C is off.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    on an 05 columbia, the a/c light shows it on when you switch to defrost. Setting bunk to low will also turn it on.
    GrapeApe Thanks this.
