Fifth Wheel Adjustment
Discussion in 'Experienced Truckers' Advice' started by GreenAction, Nov 24, 2015.
  1. GreenAction
    GreenAction Bobtail Member
    What is the best placement of fifth wheel if hauling bulk liquids?
  3. FuzzFace2
    FuzzFace2 Medium Load Member
    417
    137
    Jul 27, 2014
    Angier, N.C.
    LPG, hot asphalt & bulk cement/fly ash with a twin screw the pin is between the 2 axles to maybe just a little forward of that.
    Thing is first to watch space between rear of tractor and landing gear of trailer.
    Then what is the weight on each axle front of truck to rear trailer.
    BTW I have not moved the 5th wheel on any of the trucks I have driven.
    Dave ----
  4. AModelCat
    164,610
    Once you get it dialed in so you can max out payload without being overweight on either the steer or drives you're good to go. Usually just a bit ahead of center of the drives.
    White_Knuckle_Newbie Thanks this.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    I normally run about 4 notches back from the front, works like a charm
  6. MACK E-6
    50,016
    238,133
    I would also add that you mind the distance between the front on the trailer and the rear of the cab.
    Beyond that, my suggestion would be to find the setting that causes the drives and steer to approach their limits while loading at roughly the same rate, which allows one to maximize payload.
    G13Tomcat and AModelCat Thank this.
  7. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    Kind of a strange twist on this question. Looks like I will be getting a tandem truck but I will only be pulling one trailer with my own personal equipment on it and the trailer is relatively light. The trailer has fixed axles and weighs 35k loaded including the trailer weight.
    I could put the fifth wheel all the way forward or all the way back and not overload any axles nor would I have any clearance issues on the front or with the landing gear.
    Any particular place I should set it for better handling or other reasons? I was maybe thinking all the way forward for a shorter overall length but I really don't know.
  8. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Like others have said. A setting that max's the steers and the drives. Will give you the most weight on the trailer.
    The tanks i once pulled, were single bore. and weighed 12,5 on steers, 34 drives, 32 trailer. 78,500 was max gross. With a full tank of fuel. If you want to run 1/4 tanks, THEN, you'd be able to get more on the trailer.
    Now, if you can find a way to raise the 5th wheel or front of trailer somehow. You can get more weight on the trailer and gross closer to 80,000.
    THAT'S with the single bores i once pulled. I've seen some tanks that were wider in the back then front. The trailer had a slope towards the rear.
    MACK E-6 Thanks this.
  9. MACK E-6
    50,016
    238,133
    Snowwy makes good sense here.
    This is why tractors that routinely oull tankers are specced with the high stands under the fifth wheels, so as to allow the liquid to shift toward the rear to maximize payload.
  10. shivver
    shivver Light Load Member
    103
    48
    Oct 5, 2012
    Pennington,NJ
    It doesn't matter where the pin is,,,,use common sense. look at the back of the trailer, for they are all different. You want to mimic what is happening in the rear. If there are 3 inches overhanging the the tandems to the rear, you want 3 inches overhanging your drives to the front. Make it even. A fifth wheel too far back will not only attract the dot, but will invite unwanted handling characteristics, such as reduced steering control and a really bumpy ride.
  11. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,799
    Aug 12, 2007
    Kansas city,Mo
    A fifth wheel set to the rear will do nothing to attract the attention of the DOT. Where do people come up with these things? Almost everyone at my company runs with the fifth wheel all the way back because most of our trucks are front heavy. I'm 12.3k on the steers empty with full tanks.
