Fifth Wheel Placement
Discussion in 'Questions From New Drivers' started by DevJohnson, Aug 16, 2018.
  1. DevJohnson
    DevJohnson Medium Load Member
    340
    153
    Nov 27, 2017
    Hauling a Kenworth t680 with 53ft trailer. OTR if it’s matters. Wanting to know where my fifth wheel should go.. leaning more towards forward as much as I can I guess it may be better for turn radius
  3. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Assuming it has a typical fleet truck spec placement, I’d start at the far forward position. When you have very near 34,000 on the drives, full of fuel, make note of the steer weight with you seated. If it’s under say 12,400, I’d leave it alone.
    In my new freightliner with big Detroit engine, I ran it far most position for a year and would see about 12,500. Never had any issues at scale houses, but I recently moved it back one hole and now see about 12,300. I think I’ll leave it there. Ride is not noticeably different.
    The less gap you can achieve between cab and nose of a van or reefer, your mpg will improve somewhat.
    DevJohnson Thanks this.
  5. DevJohnson
    340
    153
    Nov 27, 2017
    Awesome thanks man
  6. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    For fuel economy, as far forward as you can legally scale the load and make the turn radius without tearing your fairings off.
    It lessens the drag of air swooping in and bouncing off the trailer.
    Tb0n3, MACK E-6 and DevJohnson Thank this.
  7. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Put it where your trailer barely hangs over the edge of the front drive. Then leave it alone!
    JTAN and DevJohnson Thank this.
  8. TripleSix
    133,260
    If you’re pulling a stepdeck or rgn, be mindful of the much narrower kingpin settings.
  9. DevJohnson
    340
    153
    Nov 27, 2017
    Just a dry van
  10. MACK E-6
    49,997
    237,994
    Tankers and flatbeds usually have that too.
  11. MACK E-6
    49,997
    237,994
    One suggestion would be if you slide up, do it in a big empty lot. That way you can slowly simulate a turn to ascertain whether or not you’ll have any equipment conflicts.
    stillwurkin, Tb0n3 and DevJohnson Thank this.
