Fifth Wheel Question
Discussion in 'Experienced Truckers' Advice' started by jmconneely, Apr 7, 2012.
  1. jmconneely
    jmconneely Bobtail Member
    19
    13
    Mar 28, 2010
    Federalsburg MD
    I have looked all over this forum for this question but no luck.
    I work for an excavation company moving equipment. I was wondering if there are different grades of fifth wheels.
    My heaviest load in a 320 CAT excavator. It is around 48,000 lbs. My problem is, the fifth wheel always seems to have a little slop. Enough that I can feel it when taking off.
    The mechanic has rebuilt it and adjusted it but in no time I feel the slop.
    Is there a fifth wheel that can handle the continuous hooking and unhooking of the goose neck from the trailer? I try to back into the hooks gently but sometimes that is tough to do.
    Hope I have put enough info in this post to get some good suggestions and answers.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    It may not be the 5th wheel, the kingpin may be the culprit.
  4. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I've noticed the same thing on our older trailers. Check the kingpin. They rub down over time. Might need a micrometer to tell. But it could be the problem like mentioned before
    Ethan
  5. Marc Letourneau
    Marc Letourneau Light Load Member
    119
    26
    Feb 23, 2012
    Worcester Massachusetts
    I do agree that the king pin is most likely your problem if a new wheel did not tighten it up.. Change is asap because it will beat the hell out of the new fifth wheel head..
    To answer your question its a yes, They do make heavy duty wheels for different applications.. We run Holland plates on our truck and we drop and hook quite frequently.
    Here's a link for the different wheels.. http://ww1.safholland.us/sites/usa/en-US/products/fifthwheels/heavydutyseries/Pages/default.aspx
    Hope this helps!
  6. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    Those plastic grocery bags make great disposable gloves for inspecting a greasy kingpin, and they're thin enough that you can feel wear on the kingpin though one.
    Peel it off and chuck it after you're done.
    aiwiron and jbatmick Thank this.
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Just because he "rebuilt" the fifth wheel doesn't mean it is good. The collar eventually wears out and the entire plate needs replaced. Jost has come out with a new plate that has a replaceable collar tho, for those of you that do a lot of drop and hook stuff.
  8. jmconneely
    19
    13
    Mar 28, 2010
    Federalsburg MD
    Thanks for all the responses, the king pin was replaced not too long ago. I will definitely double check the wear on the pin and and have the the jaws on the fifth wheel adjusted.
  9. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    May want to check the connections between the adjusting bolt, arm and leaver also.
    I am no mechanic but you may want to check, something is indefinably wrong as you know by now.
  10. jmconneely
    19
    13
    Mar 28, 2010
    Federalsburg MD
    I will, I wish our mechanic was more receptive to ideas.
    He acts like he listens but then the know it all attitude kicks in.
  11. okiedokie
    okiedokie Road Train Member
    13,775
    108,918
    Jun 13, 2011
    PNWET
    Trucking 2.0-Find out if he's a drinking man or whatever his deversions are. You will be his priority on get it fixed right the first time,guaranteed.
    aiwiron Thanks this.
