Fifth wheel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mmk trucking, Dec 16, 2025.
  1. mmk trucking
    mmk trucking Light Load Member
    155
    130
    Mar 6, 2016
    I have a fountain 7000 fifth wheel Everytime it's cold outside I have trouble releasing it.the mechanic took it off and power washed it and lubed it but it's still doing it does any know what the problem is or fix
    Trucker61016 and Rideandrepair Thank this.
  3. Cdemars316
    Cdemars316 Road Train Member
    1,021
    6,578
    Nov 10, 2018
    Grease it with the correct low temp grease
    Rideandrepair and Bean Jr. Thank this.
  4. mmk trucking
    155
    130
    Mar 6, 2016
    I will check into it I just use lucas red and tacky grease thank you
    Rideandrepair Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Do you back up to the trailer gently , set the brake and then pull the release handle?
    Rideandrepair and Diesel Dave Thank this.
  6. mmk trucking
    155
    130
    Mar 6, 2016
    Yes I do that right now I'm using low temp grease it seems to be working little better
