Finally going to use my reefer. Need your input.
Discussion in 'Ask An Owner Operator' started by gekko1323, Sep 2, 2025.
  1. gekko1323
    gekko1323 Road Train Member
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    Hey folks. After 2 years sitting in the yard, I'm finally going to start using my reefer. Power only has been good to me, but sometimes the turnaround time between loads can be a full day or more, so to be more efficient, I figured I give the reefer a go.
    The reefer is in really great shape. I took out the battery, which was dead (to be expected). I recharged it with my trickle charger and desulfated it. It is now as good as new. So, my question is...
    Since the reefer has been sitting for 2 years, are there any parts that I need to replace off the get-go? I guess a PM is obviously Step 1. Does the diesel fuel go bad and need replacement? Also, can it be pressure washed inside? It is very dirty due to it being parked basically in the Nevada desert.
    Thanks in advance for the advice.
    FullMetalJacket Thanks this.
  3. abyliks
    abyliks Road Train Member
    4,107
    9,657
    May 2, 2010
    ludlow MA
    If you start running cooler climate with the unit on cycle that battery probably wont last a month, they don’t run long enough to charge and don’t hold enough to constantly cycle
    Which unit? I would put a few hours on it In the yard before loading it and making sure there Freon, the pm it, keep an extra fuel filter on hand until the tank is gone, or better yet, run it down in the yard
    Sitting does these no good
  4. gekko1323
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    It's a 2012 Carrier XT2100A. Yeah, I'm going to start it today. I was just wondering if there are parts that get brittle with time and might break or something.
    Siinman Thanks this.
  5. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    Complete fluid change, antifreeze, fuel and filters, inspect your tank, probably have a bit of dust or sand in it being stored in Vegas.
    Siinman and gekko1323 Thank this.
  6. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Fuel can go bad,there should be a drain plug on the bottom of the tank. I’d try to get it loose and let a little drain out to see what it looks like,plus any water should be the first to come out.
    @reeferwrencher
  7. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    I would replace the battery, reefers are hard on batteries. Do a PM and replace the belts. I would set the temp at -10 and keep an eye on it. Check the tires for dry rot., i would drain the fuel tank as much as you can. Diesel fuel will smell like varnish when it goes bad.
  8. gekko1323
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    You guys are the best. Thanks.
  9. Ridgeline
    22,720
    123,223
    Before you do a thing, make an appointment with your closest Carrier dealer, let them go through the entire system, and have them do all the tests and fix anything that could be wrong. Maybe consider validation of the unit.
    It sitting for a while will also break down the insulation, so consider a roof coating.
    Midwest Trucker, Siinman and gekko1323 Thank this.
  10. gekko1323
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    Thanks. Does it have to be a Carrier dealer or can I take it to any reefer specialist?
  11. wichris
    wichris Road Train Member
    4,479
    9,245
    Jan 17, 2011
    You can have it checked out all you want to but be prepared to problems the first few trips.
    21/2300 have exhaust manifolds crack, vibrasorber leaks, and a few other things.
