First time driving this weekend
Discussion in 'Experienced Truckers' Advice' started by NJ Newbie, Sep 2, 2013.
  1. NJ Newbie
    NJ Newbie Light Load Member
    90
    21
    Aug 9, 2013
    South Jersey
    First time in drivers set friday I spent Friday Saturday and Sunday at in laws backing. There was a few vans and trees I had to negotiate for alley dock. He just let me go. First time took 45 mins. By Saturday did it in 6 minutes with 2 pull ups. Went out on the road Sunday night. Could not downshift one time. Couldn't get it to drop into gear. I know you need to do this here going around turns to pass cdl road test. Any pointers? I keep thinking I need to get this down especially for grades when I do get on the road. Seems like when I put in neutral to down shift I can't get the rpms where they need to be to get it back in gear. Any tips would help me out
    thanks!!
  3. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
  4. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    Skunk_Truck_2590 and NJ Newbie Thank this.
  5. NJ Newbie
    90
    21
    Aug 9, 2013
    South Jersey
    i haven't been in the trucks at school yet
  6. NJ Newbie
    90
    21
    Aug 9, 2013
    South Jersey
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Hey ain't nothin' wrong with getting some quality wheel time before actually hitting the school. Kudo's on that.
    NJ Newbie and truckermario Thank this.
  8. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
    Where are you going to drive? I ll make sure I am parked if nearby
  9. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Your worried about him and your from Chicago? I'd be more worried about those idiot illegals you have there.
    Op I use this method, if its bogging but still pulling just gradually losing speed ill do quick rev to 1500-1600 and go in to next gear down.
    379exhd and NJ Newbie Thank this.
  10. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    OP if you're having trouble with your downshifts pay attention to your tach on the upshifts. If you have for instance a 300 rpm drop between each gear you will need to increase your rpm 300 rpms when you drop a gear. That's an example of course every truck is different when it comes to shifting.
    Also remember when you're slowing down and dropping gears don't pull the truck out of gear take the revs up and get on the brakes and then try to catch your gear. It'll change everything and makes catching gears hard. Start slowing down long before you have too and drop gears that way so you don't have to be on the brakes while shifting. Keep the Jake off when you're shifting too.
    Shifting takes time and practice. Backing is an art takes a long time to become proficient at. We all have days when we can't hit a spot. Took me 45 minutes to hit a dock a couple weeks ago. And that was a 45 sight side. Only took 5 minutes to hit a 45 blind side 10 hours before. It happens.
    Just keep practicing and you will get things down. Practice double clutching and what not because they want you to dou me clutch on the test why I do not know but that's what the book and testers say. Just keep working at it and you will get it down.
    NJ Newbie Thanks this.
  11. NJ Newbie
    90
    21
    Aug 9, 2013
    South Jersey
    i think my problem was I was trying to work the clutch,brake and rev the engine all at the same time too much to think about all at once!! Thanks for the advice!!
