First Time Driving A Semi Through a Snow Storm
Discussion in 'Questions From New Drivers' started by nextgentrucker, Dec 2, 2025.
  1. nextgentrucker
    nextgentrucker Road Train Member
    1,688
    1,600
    Sep 25, 2023
    Port Saint Lucie, Fl
    Alright guys, I got my first experience driving through Snow and it was crazy... I'm honestly glad that I experienced it in the Midwest than the Westcoast cause I didn't have to chain lmao!! My biggest annoyance though was my windshield kept freezing and blocking my view. A driver told me a trick was to put some rubbing alcohol to the washer fluid tank, and use it so I was just wondering if you guys have anything for me, thanks!
  3. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Push your Air Conditioning button to it on, turn the heat to max, set vents to blow on windshield, fan on high, visors down. If you get to hot crack a window open.
    77fib77, austinmike, Sons Hero and 8 others Thank this.
  4. Truckermania
    Truckermania Road Train Member
    1,184
    1,802
    Oct 13, 2011
    Sturgis,SD
    Get some winter wiper blades. For me that has always been the best solution to prevent them icing up. Basically they are wipers that are wrapped in rubber and makes it difficult for ice to gain any traction on the blade.
  5. dosgatos
    dosgatos Medium Load Member
    602
    1,308
    Sep 18, 2012
    some say long term use of alchohol rots the rubber tubing. I did it for one season. The alcohol smell would come through the cowl vent. I buy the ice melt windshield wash. also have electric wiper blades to keep from accumulating ice.
  6. Carpenter Scotty
    Carpenter Scotty Road Train Member
    1,549
    18,228
    May 11, 2025
    Montreal
    I’ve had good experiences with the rain x windshield treatment to help with shedding ice and snow on the windshield. The best advice is above though, keep the cab/windshield hot as balls, and open the window if you get to hot, once it gathers up on the windshield you have already lost the battle
  7. tscottme
    tscottme Road Train Member
    Yeah, freezing wipers/windshield was the problem I never quite solved. There are several devices that may help but they seem better suited to an owner-ops truck than a company driver's truck.
    1. Heated washer fluid
    2. Heated wiper blades
    3. Heated strip that attaches to bottom of windshield on the inside.
    4. Special washer fluid.
    There is a myth putting your sun visors down and running defrost on high traps heat and helps. It may trap heat, having a heated top half of the windshield never seemed to help me. YMMV It is true that if you keep the cab warm/hot enough just stopping for a few minutes will make it easier to break the ice off of your wipers. I did keep a spray bottle of rubbing alcohol to spray on the windshield to melt ice but that requires stopping. It's very effective at breaking up the ice, but not preventing ice buildup.
    GM & Ford used to have a car model or two where the whole windshield had a coating and when it had electricity flowing through the coating the entire windshield would melt ice. The Crown Victoria, some wedge-shaped minivan had this windshield. Airliners have a similar thing in the layers of the material on their windshields, but it's mostly to keep the plastic layers of the windshield from getting too brittle and breaking easily at -50 C at altitude.
    77fib77, 201 and nextgentrucker Thank this.
  8. nextgentrucker
    1,688
    1,600
    Sep 25, 2023
    austinmike Thanks this.
  9. '88K100
    '88K100 Road Train Member
    1,482
    3,553
    Aug 23, 2020
    If you keep your defrost off and windshield stone cold snow won’t stick,, it just bounces off
  10. Carpenter Scotty
    1,549
    18,228
    May 11, 2025
    Montreal
    Really good point, have done that when too cold to win the battle with heat
