Fixed Fifth Wheel.
Discussion in 'Ask An Owner Operator' started by depsingh, Jun 17, 2014.
  1. depsingh
    depsingh Bobtail Member
    31
    Am looking to buy a truck but its got a fixed fifth wheel meaning its not adjustable. The company am buying it from says they pull fully loaded reefers from the midwest to cali and never had weight issues. Can i get by with a fixed fifth wheel pulling dry van no reefers with no weight issues because dry van weighs less than a reefer.
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    hould be ok, BUT grab a correctly loaded van hook up and scale it.
  4. depsingh
    31
    What do you mean by correctly loaded van hook up.
  5. damutt
    1,126
    370
    May 6, 2013
    if you van is correctly loaded(find one that scaled out correctly on anohter truck) connect to it and take it to a at scale
  6. depsingh
    31
    the thing is i already own a van thats been sitting in the yard. am thinking about using that.
  7. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    should be fine. normaly once you get a 5th wheel in the right spot there's not really any reason to ever move it. just so long as your right about 12k on the steers with 36k on the drives your good to go. my 5th wheel is basically a fixed 5th wheel now because it hasn't been moved in so many years...lol
    TwinStickPeterbilt and 'olhand Thank this.
  8. damutt
    1,126
    370
    May 6, 2013
    you mean 34k right?
    36k would be overweight lol
  9. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    yes 34 been a long day...lol
  10. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    He means find a heavy loaded van trailer, scale the load, make sure you're legal on both steers and drives.
    I wouldn't trust without verifying. Too many trucks running around over 12k on the steers when loaded just because its legal in most states. It may be legal but it doesn't do your tires and steering gear any good.
    damutt Thanks this.
  11. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    Not that expensive to change from fixed to sliding. You will probably need one sooner or later.
