Have a FL70 with 3126, it surges at idle then when I shut it down it wont start. trouble codes are 17,39,47. any one have ideas?
FL70 Freightliner surging at idle.
Discussion in 'Freightliner Forum' started by fl70renegade, Sep 24, 2012.
This might help you.
Caterpillar 3126B HEUI Engines - Notagz.comLast edited: Sep 24, 2012
fl70renegade Thanks this. -
it is secondary oil pressure issue. what oil, oil filters do you use?
I use Wix 51791
And I use rotella 15/40 engine oil.
really 3126 is made for 15W40
This engine was used by LIAZ Bus in Russia and we had many problems with oil, secondary oil pim HPOP, frozen oil filter and pressure regulator.
ECM reads code of low secondary pressure and we had do all this stuff one by one to find the problem..... (((( sometimes it seems to me it is easier to fit injection pump from 3106!!!!!!
well, you gotta some pain to find this problem
