Flash Code 34 / C-15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by boblynn, Nov 26, 2013.
  1. boblynn
    boblynn Bobtail Member
    29
    Mar 6, 2008
    Knoxville,Tn
    I was wondering if I can simple replace the sensor or does it need to be calibrated?
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    What is a flash code 34?
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Flash 34 could be 2 sensors, cam or crank position. You can simply change them, but that may not be your problem. Look closely at the wiring, especially behind the compressor. That code could be just a sensor, or wiring. In my experience, it's a wiring issue more often than sensors. Check the plugs for corrosion, give a 10lb pull test on the plug wires. I've seen the harness rub through on the compressor a few times. Those sensors are over $100 each, so it's a bit pricey to take a chance.
