Flashing DPF light
Discussion in 'Ask An Owner Operator' started by kameleon, Feb 5, 2020.
  1. kameleon
    kameleon Bobtail Member
    40
    19
    Jun 28, 2019
    My DPF light is flashing and I think it might be because my oil level is over filled. This morning it was below freezing and I thought my oil level was low so I added more. Then I realized that the oil had just contracted so now it's over filled. How long do I have before I derate? Can I make it 45 miles? Thanks
  3. kameleon
    40
    19
    Jun 28, 2019
    Forgot to mention I have a freightliner Cascadia with Cummins isx 2012
  4. JonJon78
    JonJon78 Road Train Member
    7,236
    42,952
    Jul 1, 2018
    I doubt you adding oil is causing that... How much did you add like a gallon or so?
  5. kameleon
    40
    19
    Jun 28, 2019
    Like a quarter gallon.
  6. kameleon
    40
    19
    Jun 28, 2019
    Can I make 45 miles?
  7. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    All you have to do is drive so it does passive Regen.
    kameleon Thanks this.
  8. drlmi
    drlmi Light Load Member
    76
    85
    Aug 8, 2008
    Ypsilanti, MI
    You'll have to get it scanned to know, A quart of oil one way or the other is nothing to sweat about. In fact don't add oil at all until it needs the whole gallon is usually the way to go.
    I would just keep going and see what happens next, sometimes those lights just flash when it is regening, like if you stop, its letting you know not to touch the exhaust when you get out because it is very hot. if it derates, then you'll need to find a shop and get it scanned. If you look on your visor, there is usually a sticker to tell you what all the lights do and what it means when they do it.
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Do a manual regen...
  10. kameleon
    40
    19
    Jun 28, 2019
    Did a manual regen twice and it the DPF light stops flashing and remains solid then after a 20 minutes it starts flashing again
  11. Brandt
    Brandt Road Train Member
    4,618
    6,346
    Sep 17, 2012
    Something must wrong with the DPF. If you did the manual Regen like it asked for. If it's still very cold it might not be getting hot enough to burn off the soot. The engine should crank up RPMs and turn on the injecter for the DPF and pump diesel into DPF and light it on fire. The DPF needs to reach like 800F-1,000F to burn off the soot.
