I am looking into flatbedding again. Been a few years since I did it and I was a company driver then. O/O now and would have to buy all the securment equipment. Chains.. how many and how long? Ratchet binders or flip? Any input would be appreciated. Thanks
flat bed equipment
Discussion in 'Flatbed Trucking Forum' started by jarrod, Jun 29, 2012.
Page 1 of 3
I would start out with at least 10 3/8" M70 grade chains that are 20' long. I like snap binders, but you can go with ratchet binders. You will need at least 10 of them. You also need at least 10 4" straps. I would get a couple of extra's in case you cut one. You will need 20 chain protectors, 20 edge protectors for your straps. I would also get a minimum of 2 sets of coil racks, 5 would be better. You should have 2 4"x4" beveled pieces of hardwood to cradle your coils. 2 pieces of belting for each coil rack would also be good. I would get a set of tarps. 2 steel and 1 lumber tarp with 8' drops would cover most anything. Get some carpet or blankets to protect tarps. You can get 6' blankets at Harbor Freight for about $10 or less. You will also need straps. I would start with a box of 50 21" straps. I think that is all you should need to get started. I keep a few hand ratchets for loads where I need them. While I mentioned 10 4" straps, I would buy enough for all the winches you have on your trailer. You will need 2 edge protectors for each strap. Some trailers have 12 or 13 winches. What I noted is the minimum.
jarrod, SHC, SublimeJulian and 2 others Thank this. -
Adding to g/man's list, I'd get few 2" ratchet straps, at least 4 1" shackles, and a ladder.
SHC, LostOne9, G/MAN and 1 other person Thank this. -
At one time I kept 13 2" ratchet straps on my trucks. They really come in handy. I had a load the other day which I had to use every 2" strap, a couple of 4" strap and all the winches on the trailer in order to secure it. I met a guy once who had a great ladder for flat bedders. It collapsed down to about 6' and expanded to enable him to get on top of any load. I have a couple of places on my step deck that doesn't have a way to use the sliding winches due to my container locks and sliding rear axle. For those places I use 4" ratchet straps. As time passes you may find other things that you want to add. I would not over buy starting out. Once you start hauling you will find more of what you are going to need.
Also I would reccommend 2 boxes of 21" bungee's if you are going to carry a full set of 8' drop tarps, 2 different length winch bars, a good pocket knife, as well as all the other stuff listed already. I would also consider some 5/16" chains as well for smaller and lighter stuff, and for header chains. The smaller chains make it a little easier sometimes, but just make sure you use them according to their WLL
jarrod Thanks this. -
If you are going with ratchet binders, I suggest the Quickbinders. They have fold down handles and store much easier than regular ratchet binders. Cost a little more, but worth it.
Walmart sells this ladder for $139 on their website, but it was only $79 when i went to my local store and bought it and it has been a great help. I keep mine inside my headache rack and use it all the time. It extends out to 13' tall
http://www.walmart.com/ip/COSCO-13-World-s-Greatest-Ladder/11150978
I have also ran into a guy who had this ladder and it was really nice if you have limited storage space, but about $100 more
http://www.walmart.com/ip/Xtend-Climb-Pro-Series-785P-15.5-Telescoping-Ladder/14971895jarrod Thanks this. -
I bought a similar foldup ladder from Home Depot, except it is a 17 footer. Got lucky and caught it on sale for under $100.
You need a ladder just to climb up to your seat at the lunch counter LOLAutocar Thanks this.
Smartarse! Keep it up and I'll beat the heck out of your kneecaps.
SHC Thanks this.
Page 1 of 3
