Flatbed question
Discussion in 'Questions From New Drivers' started by singleton2787, Aug 15, 2025.
  1. singleton2787
    singleton2787 Bobtail Member
    12
    19
    Jul 11, 2025
    Texas
    Hauling these 50-foot steel roof trusses and having some issues. Load keeps shifting even though I've stopped to re-tighten straps like 16 times already over 200 miles.
    Here's what I've got:
    • 6 bundles of trusses, each wrapped with metal bands front/back, 2 layers
    • Sitting on wood decking
    • Straps over the top at 20 locations
    • BUT there's gaps between each bundle where they can slide against each other
    • Front and back lower trusses are lifting away from the wood at front and back
    I'm reading 49 CFR 393.110(d)(2) says structural steel needs to be "blocked to prevent sliding in all directions" - but there's NOTHING between these bundles to stop them from moving.
    ❓ QUESTIONS FOR YOU EXPERIENCED FLATBEDDERS:
    • Is this load legal as-is?
    • Should there be wood blocks BETWEEN each bundle?
    • Am I missing something obvious here?
    • What would YOU do in this situation?
    D.Tibbitt and nextgentrucker Thank this.
  3. Ruthless
    Ruthless Road Train Member
    9,154
    90,833
    Aug 28, 2010
    The City.
  4. Long FLD
    Long FLD Road Train Member
    12,807
    53,565
    Mar 4, 2015
    Pics? If there are gaps between the bundles it will keep moving. Are you allowed outside the truck while loading to make sure they’re loading correctly?
  5. Kenworth6969
    2,979
    9,331
    Jul 3, 2020
    Biggest thing that pretty much goes for all loads is how you're loaded.
    You want items loaded pushed together as tight as possible.
    If there gaps when loaded there will be shifting and straps/chains will loosen.
    If items are banded like crap or loose make the shipper reband them also.
  6. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Pictures would help.
    Hope you got it fixed.
  7. Ddh77777
    Ddh77777 Light Load Member
    163
    270
    May 28, 2025
    It's hard to imagine exactly what you're describing without a picture. You should layer the securement even if it's just two. You could work the straps in from the ends and it would still help. You could also gut wrap the layers to each other with a ratchet strap connected to itself through both layers.
    D.Tibbitt Thanks this.
  8. Ddh77777
    163
    270
    May 28, 2025
  9. D.Tibbitt
    156,704
    Steel joists?? These loads are very dangerous. We haul alot of these. Sometimes legal length and most times way over length.. you want to strap every layer and its good idea to throw a chain up front pulling backwards to prevent them sliding into your cab in a hard brake event. And they will slide very easily.
    You want to make sure to alternate your straps pulling on both sides, otherwise they will shift towards the side youre pulling on if they are all strapped to the same side. Definatly post some pics we can get you lined out
  10. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,011
    2,077
    Dec 15, 2021
    Belly wraps would help,bind 2 layers together.You have enough straps.
    fcfightermma and D.Tibbitt Thank this.
  11. D.Tibbitt
    156,704
    Not sure if this helps or not @singleton2787 , this is how i do it.. but u should probably throw more belly straps than me. I am a idiot and get lazy sometimes, especially loading these in the arizona heat they take forever to tie down..edge protection is a must, it dont look sharp but i have cut straps on these before.. and cinch them down real tight. You got to go around the trailer multiple times until ur winches stop loosening up. takes a couple rounds.
    i got some more pictures somewhere i can find of more of these loads ... Sometimes the loaders like to throw a pallet of angle bar on top of all the crap , which makes it even more fun.. also i only put my dunnage at the front and back of the trailer, because the trailer arch will bring the middle of the joists to the trailer as they bend
