Flatbed to Alaska
Discussion in 'Flatbed Trucking Forum' started by 4way, Oct 24, 2014.
  1. 4way
    4way Bobtail Member
    6
    Jan 22, 2014
    Will I have any problems going through Canada to Alaska with a 53' drop deck California legal?
    Chinatown Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Are you a felon or had a dui. If not than should be ok.
  4. Chinatown
    Chinatown Road Train Member
    77,679
    184,088
    Aug 28, 2011
    Henderson, NV & Orient
    Are spread axle drop decks legal in Canada?
    A long time ago got a big ticket for entering Canada heading to Burnaby with a spread axle drop deck. The clown told me the spread axle isn't legal.
    Maybe it is now though; I don't know.
    rank Thanks this.
  5. walterjacobo15
    walterjacobo15 Light Load Member
    104
    91
    Aug 23, 2014
    Here and there
    WB 244" or less, and not more than 75' long tractor and trailer combined (nose of tractor to tail of trailer).
    10' spreads are allowed in BC, but ONLY if the sum of both axle DOES NOT exceed 20k Lbs.
    Double check this info. My junk is from 2002. It might be different now. GL!
    rank and macmanboomer Thank this.
  6. kewphotog
    kewphotog Light Load Member
    56
    25
    Sep 30, 2014
    Dacula, Ga
    Make sure you have no guns, not even a bullett. If you do your can be confiscated and you'll be serving time....
  7. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    I would think by his California legal statement , he can slide his spread together . just a wild guess though.
  8. macmanboomer
    macmanboomer Light Load Member
    72
    56
    Oct 19, 2014
    TN
    The above statement about only having 20k on a 10 ft spread is accurate in SOME provinces. I believe they also regulate the distance from the king pin to the axle distance a little different.
    I am certainly no expert, but I do know that the laws are different in each of the Canadian provinces.
    Best thing is to figure out your route & check with the provinces you'll be going through.
  9. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Sounds that way to me also!
    Look up Winchester Magnum and Skate-board on here. They both have recent experience running up there.
  10. walterjacobo15
    104
    91
    Aug 23, 2014
    Here and there
    California legal means 40' kingpin setting (kingpin to center of trailer axle's). Different manufacturers come about this setting by different means... Max Kingpin for BC is 41'.
  11. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    If it's a spread, you can't have more than 20,000 pounds total on the trailer, that's 10k each axle. You should be OK with up to 272" (with permit) wheelbase if you're cali legal, as long as you are under 75' in total length. Do you have the proper licensing for BC?
