FLD 120 cab level air lines?
Discussion in 'Freightliner Forum' started by 97Freightshaker, Oct 12, 2014.
  1. 97Freightshaker
    97Freightshaker Bobtail Member
    I have a 97 fld 120 freightliner day cab and need to replace the cab air level arm because it is leaking. Does anybody know how to take the air lines off this arm??
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you dont have the type that have brass nut holding line on, then use small open end to push plastic ring in to valve that will allow you to pull line out of it. push it in and pull line to release line, or you can replace it with old type after you cut line?
  4. 97Freightshaker
    Mine had the plastic rings. Thanks for the help!
