fld112 parking lights
Discussion in 'Freightliner Forum' started by truckerbangin, Nov 14, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    i have a 1997 fld112 not getting any parking lights on cab of truck if i turn on parking light switch i get signal to the trailer pigtail but none on the truck itself. aswell as the tail lights are staying on very faint with truck on or off.
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
  4. truckerbangin
    268
    45
    Jan 22, 2013
    Brake lights are working perfect
  5. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    What's the shape of the fuse box? Had one that was massively corroded, caused a bunch of wiring issues.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Check the relay, if I remember right, the FLD's had 2 relays, 1 for the tractor and 1 for the trailer.
  7. truckerbangin
    268
    45
    Jan 22, 2013
    There was like 4 relays in one row that was coroded real badly swaped out coroded relays for new ones. I wish the i knew whick relay is which all the relay have no labels
  8. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    Good luck with that, they were labeled, but after 10+ years they either fell off or are near impossible to read. Sometimes you can read them with the right angle on a flashlight. FLD wiring is simple, it's the yellow wire :D.
    If you have corrosion in there, you may have a windshield leaking, or leaked at some point.
