Flexible antenna cable?
Discussion in 'CB Radio Forum' started by Snow Crab, Feb 19, 2015.
  1. Snow Crab
    Snow Crab Bobtail Member
    46
    12
    Feb 26, 2013
    Brandon MB
    I've found that alot of the time, the antenna cables break at the doors because of the constant opening and closing. Woven core cables are supposed to be more flexible than solid core, so I bought the Wilson 18 foot cable , but at -20 last night it was pretty stiff so I was wondering which antenna cable remains the most flexible at low temperatures.
  3. Powder Joints
    7,968
    8,350
    Sep 25, 2007
    Rosamond, SoCal
    Run it thru the wing window, do not close the door on it.
  4. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Unless you are slip seating, find a place in the firewall to run it thru. There is usually a fairly easy passage way if you look for it. The Cascadia has a rubber grommet on the driver's side they tell me is easy to access and run your cable thru.
  5. Snow Crab
    46
    12
    Feb 26, 2013
    Brandon MB
    I am slip seating, and need to roll and unroll every day. Hard to get a neat coil when it's stiff from the cold.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    As cold as it's been in most of the Country last few week's...Your not going to find anything that's going to stay flexible...Except for maybe a string and two tin can's.
  7. Snow Crab
    46
    12
    Feb 26, 2013
    Brandon MB
    You mean the Frightliner factory CB setup?
    jessejamesdallas Thanks this.
