Fluo lamp replacement with LED
Discussion in 'Freightliner Forum' started by Pablo-UA, Apr 25, 2014.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Hi to all. I have grote fluorescent lamp (Philips lamp) and it goes dim. so I wanna install bright 5 wt LED.
    The idea is to remove fluo lamp, and install trigger relay (I want to keep control from dash and from sleeper).
    Does anyone have LED sleeper lamp?
  3. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ok, I got fog lamp trigger relay and fit LED on sleeper lamp plate
    first idea was to use two LEDs, bright and dim one, but finally I decided to use only one raley
    25(2)+2 Thanks this.
  4. 25(2)+2
    18,759
    45,962
    Sep 18, 2006
    the road less travelled
    Most of the newer trucks I have been around lately in this country have gone to incandescent, but I'm glad you have figured out a way to deal with your problem, Pablo, and I have experienced what you describe with the dim fluorescent lighting.
    Another problem is that the fixture goes bad, and just changing the hard to find lamp doesn't fix that. What you need is the really hard to find fixture.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ultra bright LED is $10 only. It needs radiator, so I mounted it on stock aluminium plate with thermal paste
    Trigger relay I used if from car (23.3777 by russian standard). It it trigger relay, I had to use it to switch light from sleeper and dashboard.
    really LED is the future
