? for oil analysis experts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Nov 30, 2015.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    what would cause high viscosity ? i'm not using any addictives.
  3. taxihacker66
    taxihacker66 Road Train Member
    1,354
    1,287
    Feb 26, 2012
    Concrete jungle.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    This is oil that is too thick. I suspect some blends have chemicals added to prevent oil from being too thick so it flows properly. These chemicals are probably worn down.
    ShooterK2 Thanks this.
  5. OJTTrucker
    OJTTrucker Bobtail Member
    29
    11
    Nov 28, 2009
    Granny Lane
    Just out of curiosity, how long would oil have to remain in the crankcase before those chemicals wore down? ;)
  6. mtoo
    mtoo Road Train Member
    1,940
    4,522
    Jan 15, 2011
    Retired on bended knee
    If it's just one sample ignore it. Drain the oil then re sample @ 10-12k. Labs can and do screw up a sample at times.
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Spot is usually the culprit unless someone put that lucas garbage in the oil.
    Heavyd Thanks this.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    You'll get nothing but guesses without more information. What does the rest of the same look like? How much did viscosity raise? How old is the oil? Soot, oxidation, nitration and several other things could cause a viscosity increase, most of which will show on the oil sample as elevated as well.
    Heavyd and blairandgretchen Thank this.
  9. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Heat can cause thickening. Are the oxidation levels high as well? What oil and what is the tested viscosity? Does this engine run hot and or work hard?
  10. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Soot was 135. Nothing was flagged as elevated, it was just a comment. I'm not loosing sleep over it , just curious.
  11. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I would love to know more about oil sampling. We send ours away. This is an area I don't know too much about, so I really can't comment on how long chemicals last and what not. Too many variables to factor in as well.
