Forklift weight
Discussion in 'Ask An Owner Operator' started by AriGab, Feb 1, 2024.
  1. AriGab
    AriGab Light Load Member
    62
    27
    Feb 3, 2023
    OK I apologize for the stupid question. So if I have a 53' dry van trailer with 68000 lb gvwr and I am loaded at 80k how do you figure in the weight of the forklift entering the trailer?
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    Not sure I understand the question? Every forklift should have its weight stamped on its ID tag, required by OSHA.
    Are you worried the weight of the forklift will be too much and will break the trailer? I can’t say that has never happened, but as long as your floor, frame rails, and crossmembers are in good condition, that shouldn’t be a problem.
    Most forklifts that you see entering trailers are around 8k lbs. or less.
    Feedman, W923, Siinman and 6 others Thank this.
  4. Pepper24
    Pepper24 Road Train Member
    2,098
    1,640
    Dec 3, 2010
    You’re confusing trailer weight with gross weight of the combination of truck and trailer.If you have 50,000 of freight and most forklifts that load vans are in the 5000 lbs range that’s only 55,000 pounds well below the 68,000 pounds rating
    86scotty, AriGab and Kyle G. Thank this.
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    The gvwr is for going down the road. As @Kyle G. mentioned, your concern with the weight of the forklift is the psi on the floor while loading it. The forklift will not be in the trailer as you're going down the road.
  6. Ridgeline
    22,718
    122,941
    No don't worry about it, the trailer is made to be unloaded by a forklift.
  7. 201
    201 Road Train Member
    12,743
    26,206
    Apr 16, 2014
    high plains colorado
    Well, that greatly depends on the condition of the floor. I've hauled some rail pigs that the forklift did indeed go through the floor. Not to the ground, but a good hole, and a freaked out operator. Oh, it will creak and moan, but unless you want to fingerprint the loads, the forklift shouldn't hurt it none.
  8. LOTSO
    LOTSO Heavy Load Member
    876
    2,098
    Mar 28, 2023
    I wouldn't worry about a SINGLE Forklift. It's the SINGLE/DOUBLES you have to watch out for.
  9. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    The 80k weight limit is for in motion bridge weight. You are not hauling the loading vehicle so no it does not play into the weight.
    I have to admit I don't think this is a dumb question at all. It tooke 4 months to understand pallet weight was included in the load weight.
  10. 201
    12,743
    26,206
    Apr 16, 2014
    Not always. I've had places tell me, "pallets don't weigh anything", then you come up 800 pounds overweight.
  11. Soltaker
    Soltaker Bobtail Member
    46
    77
    Sep 4, 2016
    Deer Park, WI
    Don't forget about the robots too !
    Buddy of mine brought an old trailer to Mark Anthony Brewing in Waddell. Robot broke thru the floor via 2 bad crossmembers while loading. Thankfully for him, it only broke thru a few inches and there was no damage to the robot. Guy on the dock claims it's a million dollar machine, lol
