Forward Rear Axle Temperature
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by KeepUp, Apr 19, 2020.
  1. KeepUp
    KeepUp Bobtail Member
    17
    20
    Jul 20, 2017
    Iowa
    Hello.....
    I took my 2015 Volvo to have the front and rear axle seals replaced because of the major leaks it was leaving on the ground. I get the truck out a week later. Get under a 30,000 lb load and 400 miles down the road the check engine light came on. Error code on the dash is MID 140 PID 77 FMI 5 and when I searched the Volvo Service Manual the code states 'FORWARD REAR AXLE TEMPERATURE' Abnormally low current or open circuit | Sensor resistance above 100 kOhm | Faulty harness Faulty outdoor temperature sensor.
    I have the following questions:
    Is this something the mechanic missed when doing the seals? Either checking a plug or circuit was bad or forgot a procedure step?
    Can this cause serious damage?
    Can this cause a trickle effect of problems in other areas?
    Thank you for your help.
    Joe
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    I would look and see if the wires were plugged up on the sensor.
    KeepUp and Rideandrepair Thank this.
  4. KeepUp
    17
    20
    Jul 20, 2017
    Iowa
    Thank you for the response.
    Is this something I can see or will have to take back to the shop?
    Rideandrepair Thanks this.
  5. Mattmanstroked
    185
    279
    Nov 24, 2019
    Yes you can see. Should be wires going to the rear of the axle housing. About 1/3 of the way from the bottom of the big round part. Be easiest to see on rear most driver axle. That will give you an idea of where to look on front drive axle.
  6. 201
    201 Road Train Member
    12,756
    26,246
    Apr 16, 2014
    high plains colorado
    Piece of black tape over the code error light,,just another reason you can have newer trucks. Old "Stewart-Warner" temp gauge never let me down.
    KeepUp Thanks this.
