Freight driver late every week
Discussion in 'Ask An Owner Operator' started by Frustrated customer, Mar 9, 2021.
  1. Frustrated customer
    Frustrated customer Bobtail Member
    Mar 9, 2021
    Literally 5 hours late every week. Is there anything we can do about it?
  3. Espressolane
    18,648
    116,810
    If the carrier you have been using is not meeting your service requirements, get a new carrier.
    Really about the only choice. When you find a new carrier, make sure you have clearly stated your needs.
    While this may not be the case with this carrier, occasionally some things can cause a delay. Weather, major traffic incidents, possibly loading being delayed. When this happens, make it known that you need a call to alert you to the delay.
    alds, OldeSkool and Eddiec Thank this.
  4. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    More details would be helpful? Is this a truckload where you're the only stop? Or are there other deliveries coming off that truck before it gets to you? If the latter, it's a 50/50 chance whether the problem is the carrier being ####ty or the other stops refusing to unload their portions in a timely manner
    Coffey, Farmerbob1, magoo68 and 4 others Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,624
    183,919
    Aug 28, 2011
    Henderson, NV & Orient
    If it's a multi-stop load, then other customers may be causing the delay.
  6. Frustrated customer
    Mar 9, 2021
    This is the only stop, and I understand a occasional delay. But it's literally every single week a minimum of 5 hours late.
    Farmerbob1 Thanks this.
  7. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    We had a guy we called on the way ray. Guy had no time management skill whatsoever. Find somebody else or change the carrier agreement to include late penalties.
  8. Justin Sane
    Justin Sane Light Load Member
    92
    69
    Aug 21, 2012
    Have you asked the driver?
  9. wichris
    wichris Road Train Member
    4,479
    9,244
    Jan 17, 2011
    Are you the shipper or the receiver? Because if you're the shipper you tell the carrier to fix it or you pick up the phone and call someone else.
    If you're the receiver, pick up the phone and tell the shipper to fix it or you'll buy elsewhere.
    B&*^%$ about it on here won't fix anything.
    alds, Coffey, Farmerbob1 and 4 others Thank this.
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Are late fees stated in your contract?
    IF not, notify the carrier of said changes that will be implemented on XX date and have them sign it or pound sand.
  11. Ridgeline
    22,721
    122,981
    Details, we are all guessing.
    If you are the consignee, get another carrier.
    alds and Farmerbob1 Thank this.
