Freightliner cascadia 2013 back parking light issue
Discussion in 'Freightliner Forum' started by Junaidkh879, Jun 29, 2020.
  1. Junaidkh879
    Junaidkh879 Bobtail Member
    Hi any buddy knows where I can find the back parking light fuses r relay my back parking light is not working when my parking light on but working on breakS and L/R signals I check all the fuses in the glove box. But nothing find anything. Can any buddy knows plz help
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Rear tail lights are powered from the SAM chassis & they have no fuses but are logic controlled. I understand that to mean the SAM chassis chassis will shut off the circuit if there was dead short for example. The SAM Chassis is located on left firewall on the engine side. Make sure have have all the covers in place as they can get wet and have problems. Power to left tail light is connector X58 Pin 18 right is X58 but pin 3. The grounds are X58 pin 5 for right and X58 pin 8 for left. I also have run across situation where both tail lights were burnt out but the stop light portion of the light was still working on each light.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    Check for a broken wire
  5. Trenton325
    Trenton325 Light Load Member
    102
    153
    Feb 7, 2019
    Not sure what a back parking light is?
    If you mean Back up light there is switch on your transmission no relay.
    All the other light or ran by fuse box under hood on fire wall.
    There's a break switch behind foot petals
