Freightliner Detroit engine 60- 2008 Engine Protect Warning
Discussion in 'Freightliner Forum' started by keepontrucking81, Jul 14, 2013.
  1. keepontrucking81
    keepontrucking81 Light Load Member
    210
    41
    Jun 27, 2013
    Chicago, IL
    Im.in PA now fully loadded all freaking night hills up and down..
    Just now my ENGINE PROTECT (IN RED) COMES ON AND OFF then after that
    My engine lite is on. I pulled over to the plaza hoods popped oppen. Now my temperature isn't going down its at 200 past 10 mins..wtf
  3. coastie
    coastie Road Train Member
    Does your engine fan come on at all? I drove one truck where it ran hot all the time the shop did not believe me said it normal, They ended up putting a manual fan switch on it after it blew the engine on another driver after it already had on me once also. That is one of the reason I dislike Detroits, they love to run hotter than others what I have seen.
  4. keepontrucking81
    210
    41
    Jun 27, 2013
    Chicago, IL
    I figured itt out thank god. For the manual ..its says that its a high. Percent. That the fluids "are low. I sae my radiant fluid was undder minimum line..I added yhat beeotch she's all loww now lites gone past 45 mins I'm BEAT! I have to drop these #### onions off I'm calling it the day. E safe driver's
    Keep on trucking!
    The Challenger Thanks this.
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Gotta do your pretrips and check levels. If my truck hits 200 I pull over, give the truck a brake, and check coolant levels again.
  6. FLATBED
    FLATBED Road Train Member
    With your supposedly 12 years as an HVAC tech you must have some MECHANICAL skills , things need to be looked at and in this weather things do OVERHEAT , when you get a chance check your rad , your rad is the same as the condensor on a A/C system it needs to be CLEAN for proper airflow across it.
  7. MJ1657
    MJ1657 Road Train Member
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    Your posts make my head hurt.
  8. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    I know we are not supposed to critique spelling, grammar, or punctuation however.................
    MJ1657 and keepontrucking81 Thank this.
  9. keepontrucking81
    210
    41
    Jun 27, 2013
    Chicago, IL
    Hahah sorry guys ill proof read next time. Stupid smart phones
    Keep On Trucking!
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Surrrrrrrrre, blame it on the phone.
    sal Thanks this.
  11. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    Most Freightliners when water level is low it shuts the truck off and won't run.....soon as I hit 200 my fan cluth comes on and up there it stays on and is hard to shut off engine temp has to drop below 170
