Freightliner Eaton Auto
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MTMAUS, Dec 10, 2022.
  1. MTMAUS
    MTMAUS Light Load Member
    256
    208
    Sep 28, 2019
    Hey, I have a freightliner with an Eaton smart shift 2 pedal auto.
    When taking off from 4th gear the truck sounds like its going to stall before then revving up normally. It's only for a few seconds, pretty much the same as if you try and take off in high range by mistake on a road ranger.
    The driver also says it sometimes gets stuck shifting.
    I am thinking the XY shifter? Is this the first thing you would try? And other ideas?
    Thanks
  3. MTMAUS
    256
    208
    Sep 28, 2019
    Or would it be time to do the clutch? It's got 1,250,000 kms on it, and I doubt it has ever had the clutch done.
  4. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    First you need to check if there is any transmission codes (Roadranger.com). Try taking off in manual and see what happen. Try isolate the problem to see if it's transmission or engine problem.
  5. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Why starting in 4th?
    flood Thanks this.
  6. MTMAUS
    256
    208
    Sep 28, 2019
    That's just what they do, all of my freightliners start in 4th in the auto
