Freightliner m2 08 blower motor issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Crwtek15, Jan 25, 2020.
  1. Crwtek15
    Crwtek15 Bobtail Member
    Hey guys! Recently been having issues with the blower motor on our 08 M2. When I take the green connection off the fuse block, it’s charred and burnt up, however cleaning the connection and putting it back seems to get the blower motor working again for a period of time. It can’t be a bad motor as we just replaced it
    With a new unit. Any ideas on how to stop it from losing connection? Also why would the connection be blackened?
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Has been a problem with M2 since its inception. Wire was not large enough to handle blower motor electrical draw. You can't buy new connector for PDM (fuse box) Go to junk yard and cut one off and splice. Something else to fix before it happens is the connector about 12 inches from blower motor. Follow blue and black wires and pull apart connector, if you can (probably already melted together) Cut off connector and butt splice the 2 wires.
    spsauerland, Crwtek15 and mhyn Thank this.
  4. Crwtek15
    I recently replaced the blower motor and it came with a jumper wire that adapts the new connection for the new motor. When you say that I can’t buy the connector for the fuse block, do you mean. The physical fuse panel or the harness that plugs into that? I’m fairly sure that the harness end is the problem, but I’m confused as to why it stops working after a period of time. I can clean the connection and re connect it and it works every time. But then you’ll be driving and it’ll cut out. Very odd.
  5. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    The harness plug itself.
    spsauerland Thanks this.
  6. jesandmelis
    jesandmelis Bobtail Member
    Connector is available. Cromiance is the brand name. Part number is CC-675-575
