Freightliner marker light issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jberry805, Mar 12, 2024.
  1. jberry805
    jberry805 Bobtail Member
    2015 freightliner m2. IT IS NOT THE TRAILER, truck does it with multiple trailers.
    No trailer, all lights work fine. Key on or engine on
    with trailer, key on, lights on, everything is fine
    With trailer engine on, marker lights shut off after a few seconds. Restart truck lights come back but turn off again
    any suggestions
  3. JB7
    JB7 Heavy Load Member
    964
    1,676
    Dec 13, 2022
    Laurel, MD
    First try a new or known good light cord. If nothing changes I would then check the receptacle wiring (what the cord plugs into) on the tractor and make sure all the connections are clean and tight.
  4. jberry805
    All connections are good at the 7 way, even tried removing it from the truck so it doesn’t short to ground and still nothing
  5. 062
    062 Road Train Member
    6,308
    33,914
    Oct 20, 2013
    Does it have the relays behind drivers seat?
    Maybe a weak relay that’s not holding contact with the truck running?
  6. SmallPackage
    5,748
    18,396
    Dec 20, 2019
    Marion Texas
    Sounds like a marker light relay in the circuit breaker / fuse box or the light switch on the dash is getting overloaded and intermittently cutting off. The switch may seem fine on the outside but the contacts inside go bad from years of heat and load on them. They can work fine until you add the extra load on them from the trailer lights then it makes them wig out.
    Hammer166 Thanks this.
