Freightliner springs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stonefly4, Mar 2, 2020.
  1. stonefly4
    stonefly4 Light Load Member
    162
    122
    Oct 4, 2018
    My 93 FLD 120 has the hockey-stick-type rear springs. They are twisted down. The airbags sit at an angle. It feels like the suspension is bottoming out with heavy loads on rough roads. The springs are the originals, never replaced.
    My question is this: Are the springs twisted from age and millions of times flexing, or are the saddles worn to the point where the spring sags downward?
    Are these type springs known for twisting after many years of use?
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Hard to really say without seeing it. But yes, have been behind lots of older trucks bobtailing. See the rear air bags leaning. Usually due to many miles and wear. May want to have someone that is knowledgeable to get a opinion. Thing is once those air bags lean, they tend to push that direction. Slowly making it worse. You know..trying to lean more. May be a expensive fix. But it's not gonna heal, unfortunately. But it could be a bushing issue.? Not as expensive.
  4. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Also new spring bushings for sure..
  5. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    I see a lot of them off, or crooked. Even on some newer Trucks. Definitely check bushings as mentioned, But also, check the mounting brackets themselves. Top and bottom, they have a lot of wiggle room. They can be loosened up, turned or twisted, however you look at it. Then tighten up. I’ve noticed this while changing airbags out. All 4 10 yrs ago, and again 2 yrs ago. I had to redo one of them, last time, as it was crooked. If changing them out, be sure to get new fittings, and compression ferules. Makes the job a lot easier.
    stillwurkin Thanks this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Loose u-bolts.
    Hulld and Rideandrepair Thank this.
  7. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    What about rusted out alignment pins? Do they have them on rear springs? Like on front springs/ blocks?
  8. stonefly4
    162
    122
    Oct 4, 2018
    Thanks for the replies.
    I have replaced all four spring bushings. The originals were worn to the point where they were very loose.
    Replacing the bushings did not correct the problem of leaning air bags. If the springs are bent because of old age and need to be replaced, I'll just bite the bullet and endure the expense. I just want to know a little more about the problem before I spend the money. The springs are expensive. I'd hate to buy new springs only to discover that I still have the same problem.
  9. stonefly4
    162
    122
    Oct 4, 2018
    Actually, it's not the lean that worries me. What worries me is that I can feel the suspension bottoming out on rough roads. If this is happening because of worn out springs, then they need to be replaced. I'm trying to find out as much as I can before I take on the expense.
    Thanks again!
  10. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Read this PDF.
    Hulld, blairandgretchen and stonefly4 Thank this.
  11. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Are you sure the ride height is set right? Shouldn’t bottom out, unless it’s too low, not enough air, and bad shocks.or a bad leveling valve, causing inconsistency. I think you need to loosen each bag, starting with the worst looking one, loosen, the top bolts on air bag, at the bracket.one has the airline to it, also loosen bottom bolt. Twist/turn the bag, getting it as straight as possible. The top of the air bag has a dimple in it, that lines up with a dimple in the top bracket. It’s a elongated dimple, so you can turn/ twist the bag, quite a bit, and still be bottomed out flat against top of bag/ bracket. Wouldn’t hurt to loosen two bolts for bracket at the frame also.. If the springs are twisted, maybe from sitting in a twisted position for so long,I think they could be taken off and swapped, side to side. The bulletin has the proper measurements for everything.
    stonefly4 Thanks this.
