Freightliner steering (smartwheel) adjusting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Oct 29, 2019.
  1. istumped
    istumped Medium Load Member
    493
    233
    Feb 8, 2015
    What's the process too centering steering? Had truck aligned and steering wheel is off center
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    I pull the steer wheel off and center it and tighten it back down. Probably will need a steering wheel puller to get it off. A less expensive one would be at Harbor Freight store. Looks like you have a smart wheel (by the buttons on it). All i ever had to deal with is the horn button. So when you lift it, keep an eye on things/ pieces. If you have never pulled one you may want someone who has experience to assist. Not that big of a job, but just say'in.
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    You could also pull off the steering shaft at the gearbox and reposition it there, but you may have to reset the yaw sensor if equipped with one.
  5. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    They should have centered your steering wheel first of all...
    Adjusted your rears then ajusted your front-end to your rears..
  6. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    You never center the steer wheel first. Many things are, or could be changed during alignments. Shims added or taken out, bushings replaced, even steer axles have been known to be slightly bent to aquire proper alignment. So centering the steer wheel first would be putting the cart ahead of the horse.
  7. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    You don't have the amount of adjustment at the box, or the steering shaft. The splines at the box and connector have a notch with a pinch bolt that has to be inserted at a certain position. It is not a pull off ,and push back on situation.(at any position). At the steering wheel, it can be pulled off the splines and reset at any position desirable position.
  8. boneebone
    2,294
    2,365
    Mar 13, 2009
    That may be true on some newer trucks.
    My truck has a Ross/TRW TAS65 steering box and there’s no specific place to position the steering shaft on to, the spline is not position specific.
    stillwurkin Thanks this.
  9. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Ok, so why is Op's steering wheel of center after alignment?
  10. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Because they may have put shims under the u-bolts on the steer axle to get alignment correct. Even on older equipment without anyone changing anything your steering wheel can gradually be slightly off, over time and miles. Bumps, and wear and tear. Next time your talking to a alignment teck ask them. I may be wrong, but this i can say for certain. After alignment is all done and correct, then set steering wheel where you want it. Done it many times over 45 years.
  11. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Hey, if that's what works for you than more power to you..
