freightliner with mll help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Sep 9, 2009.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    hey guys I have a crazy problem that just came about I worked wed. night last week and got the truck home thur. for a little clean up and to check it over it rained and didnt not touch it until mon. it started just fine was backing up and the motor just die down and stop eng light was on light went out ran fine let it run for a while and samething motor goes down and light is on then motor comes back up light goes out...so I drive the truck down the road and it only goes to about 1500 no more and wont pull and harder back home and look around change fuel filter thinking maybe thats it same thing but it just comes and goes..motor die down never cuts off just comes back up and light goes out...what gives ...need to be at work its getting close to the bad mths for me....:biggrin_25518:
  3. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    Well there are some things that could help people in answering your question:
    What are the gauges saying when it happens? Anything dropping to zero or pegging?
    You can also go through the engine bay and start checking connections, maybe you just have a lose one on a sensor. Because you mentioned rain see if water is down in a connector.
    The behavior you're describing now is pretty much exactly what the engine protection features of most electronic engines do these days so I'm going to assume the engine protection feature is kicking in which could be any number of items such as oil pressure, temperature, etc. So you could actually have low oil or coolant, or just a bad sensor. If its a 2007 emissions level engine maybe the DPF is clogged?
    The easiest thing to do is get it into a shop and have them plug in.
  4. earthmover
    563
    20
    Jan 27, 2009
    the truck is 1997 freightliner with a cummins mll..
    the gauges never move thay stay just like they should I thought maybe a bad conn. from batt. turn everything on ac/lights/fans/heat mirr everything no drop in volt. the thing is it just does it from time to time not steedy it'' drop down and run for 2/3min then just come back on...its not the sut down light its the stop eng light...oil press. is fine its full and temp has nothing to do with it cause it does it even when I just start it up thanks for your reply.....
  5. Heavyd
    Heavyd Road Train Member
    7,824
    6,274
    Feb 4, 2009
    Ok, your going to have to get the fault codes out of it, no if and or buts about it. If not you are just going to chase your tail and waste a lot of time.
  6. PharmPhailPartsReplacer
    PharmPhailPartsReplacer Not to be confused with DinosPartsReplacer
    128
    433
    Sep 7, 2009
    Check your coolant level and sensor.
  7. earthmover
    563
    20
    Jan 27, 2009
    hay guys on this truck i have a little digital help box called road relay it has never changed since I had this truck almost 3yrs anyway today I m playing with it and on the maint. scene it reads inj1@the bottom its normal and does this for all inj then it say reserved bad device s00/f12.... can some one tell me how to work this and maybe reset stuff like oil change and trip info thats full also :biggrin_25524:
  8. Heavyd
    7,824
    6,274
    Feb 4, 2009
  9. earthmover
    563
    20
    Jan 27, 2009
    hey guys I have leaned something new today about my truck it has a switch on it that has eng.check..now I switched it on and I got the codes for the truck it came out as code 343 and code 321 does that mean I need a new ecm???? or can some on:biggrin_2556:e tell me what I need to do...thanks
  10. Heavyd
    7,824
    6,274
    Feb 4, 2009
    343 is an internal error in the ECM. The fault processor monitors the output of the injectors and communicates any faults to the main ECM processor. This code can be caused by electrical noise outside the engine. A faulty alternator, bad, or intermittent grounds, water intrusion into the ECM, water in connectors, loose connectors can cause this code.
    321 ECM has detected voltage returning from injector #4 when the ECM isn't powering #4. This is usually a short in the injector harness either outside the engine or under the rocker cover. ECM will derate the engine and limit RPM to 1400. Basically inspect for wires rubbed through.
  11. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    How or where can I find a list of fault codes. I have a 99 Freightliner with a Cummins N14. Road Relay reads. 2R5004, 1LS001, 2S015. Thanks
