Fridge question
Discussion in 'Experienced Truckers' Advice' started by tmb0507, Feb 12, 2016.
  1. tmb0507
    tmb0507 Medium Load Member
    357
    197
    Aug 11, 2012
    Folkston, GA
    Ok so the fridge in my Volvo keeps freezing everything I have it all the way down in lower it will be off so question is how the hell do I make it stop freezing all my food and drinks lol
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Sounds like the thermostat is busted. Those Volvo fridges are expensive melons.
  4. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    buy frozen food. :)
    but seriously like the other driver said check your thermostat. most likely is broken.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,919
    18,895
    Nov 1, 2010
    Burnsville, MN
    Crack the door open a bit?
    Or perhaps just turn it off every now and then.
  6. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Contact my employer and tell them you'll trade them for the fridge in truck #234. It barely gets cold even on high. :D
    BigRedNY Thanks this.
  7. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    The turning off every so often is a solution my dad came up with for the mini fridge at his office years ago. The thermostat got stuck on full blast and would freeze everything. He got one of those 24 hour timers that you used to turn on lights at your house when you're on vacation. He set every other switch to on so it would turn on every hour and off every hour. It worked like a charm and ran like that for a couple of years before another professor found a replacement at the flea market. Dad took it home and made it his beer fridge, timer and all.
  8. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    I use those timers at home. To turn on the lights and make it look like i'm home. And turn off the lights.
    banders77 Thanks this.
  9. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Mine you can't put vegetable's or nothing like that on the top shelf or they'll freeze, I found as long as you put them in the door they stay good, that's with the setting at 1.5 - 2.0 depending on the time of year.
  10. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Get a good quality fridge, Black and Decker for example. I've had my 3.2 cu.ft. over two years with no issues so far.
  11. EZ Money
    EZ Money Road Train Member
    It never hurts to pull those Volvo fridges out and clean the coils and behind them every so often too...
    You could probably get a new thermostat online for a reasonable price....
