FRO-16210C
Discussion in 'Trucks [ Eighteen Wheelers ]' started by REDD, Jul 12, 2010.
  1. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Is this the 10 speed that can be converted to a 13?
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    nope only some 9 spds can be converted
    REDD Thanks this.
  4. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    no the c at the end is the gear ratio. the convertable trans would be a RTL0C-16909A or something like that. the C before the dash stands for convertable. the letter at the end is the gear ratio. only 9 speeds with the c before the dash are convertable
    REDD Thanks this.
  5. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    No such thing as a 10 converted to a 13. Only the newer 9s will convert.
    REDD Thanks this.
  6. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    I have learned that... I ended up going into the service department & looking like a fool with that same question before I saw the responses here.
    I've got bigger problems right now though....
    What originally started off as a small coolant leak has turned into something much larger! Coolant leak is fixed... Rear end leak is fixed... Now it looks like I'm getting a new camshaft & lifters!!! That's what I get for asking them to run the overhead. And hopefully the warranty will come thru cause I don't want to pay the 3 grand for a cam!!
