Front crank seal leaking.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by seabring, Jun 19, 2013.
  1. seabring
    seabring Road Train Member
    1,844
    1,883
    Apr 24, 2011
    C15 mxs acert front crank seal leaking a small amount of oil. What is involved in fixing this? Labour time , cost etc? Downside of letting it be for now? Can it cause big probs or just going to leak a bit?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    are you sure it's the crank seal? sometimes the o-ring on the crank sensor gets weak and oil will seep out and it will look like the crank seal is leaking.
    kw9's rock Thanks this.
  4. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    a good mechanic can do it in half a day or less. depending on how easy it is to get to. on my w900 I have changed it with out removing the radiator. skinned knuckles and all, but doable.
  5. Cat sdp
    Cat sdp . .
    21,294
    76,121
    Apr 8, 2012
    Orion's Belt
    Warning off topic.....kw9's may I ask what your plan for dealing with Cali next year is ??
  6. seabring
    1,844
    1,883
    Apr 24, 2011
    Basically I won't be going into Cali with my truck. I am not going to retrofit a DPF filter or buy a newer truck. I don't have the money or desire to do either of those things.
    Cat sdp Thanks this.
  7. Pinkybuster
    Pinkybuster Bobtail Member
    8
    Feb 19, 2020
    I just installed a new crank sensor on mine and it's now leaking oil from that. Brand new and o ring looks fine. Its tight but will show oil running down out of area now. Fresh in frame and all clean so i can definitely see that where its coming from. What do I need to do?
  8. AModelCat
    164,520
    Remove sensor and check o-ring. Check sealing surface on the engine for damage.
  9. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Defective oring or defective sensor...(leaking through sensor case) or surface where oring seats is dirty or damaged.
  10. Pinkybuster
    8
    Feb 19, 2020
    Seems to be slow leak around it. That's why I thought maybe it had a second o ring to seal it against the block
