frustrated
Discussion in 'Freightliner Forum' started by bridgestone mining 707, Oct 13, 2014.
  1. bridgestone mining 707
    bridgestone mining 707 Bobtail Member
    5
    I have a 1998 freightliner fl80 8.3 cummins p-7100 injector pump we replaced it becouse the body was leaking the truck was having a problem sometimes at 65 mph it will fall on its face like its not getting fuel then around 55 mph it will pick back up and go sometimes it will do it again within 1-2 miles other times it wont any help would be verry appreciated
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Just a guess, but I have a mack that did that and it was the throttle position sensor.
    bridgestone mining 707 Thanks this.
  4. bridgestone mining 707
    5
    this truck is cable driven direct to the pump. I looked for any type of wires and there wasnt any that I could see thanks for trying
  5. davo727
    davo727 Bobtail Member
    43
    16
    Sep 29, 2014
    Cleveland, Texas
    I would think start with simple stuff like replacing all the fuel filters.
  6. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    So . . Did the truck do this before the leaking fuel pump was replaced?
  7. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Ever replace fuel line? They sometimes collapse and starve the engine of fuel.
  8. bridgestone mining 707
    5
    I replaced the fuel filter and the mechanical lift pump still have the problem I was going to try the valve under the cab for the two fuel tanks I'ii check the fuel lines while I'm in there
  9. bridgestone mining 707
    5
    yes. The truck did this before I replaced the injector pump I figured if it was leaking fuel that it was sucking air and that was causing the problem
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Is it VP-44 pump?
  11. bridgestone mining 707
    5
    its a p7100 I found the problem someone had installed a remote filter that i wasnt aware of I have only worked for this company for a short time and they didnt have verry good mechanic records on this truck. Thanks for all the help
