Fuel line freezing question
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Jan 7, 2024.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    If I don't start the truck for several weeks and the fuel lines freeze can I just plug it in for a few hours. Or wait until spring to start the truck.
    2016 cascadia
  3. AModelCat
    164,566
    No. It'll warm the coolant in the block but it won't do anything for the fuel lines. Best to mix in some antigel and run the engine so the treated fuel goes through the lines.
  4. Long FLD
    Long FLD Road Train Member
    12,845
    53,754
    Mar 4, 2015
    If you’ll need to start it after it gets cold and it’s still gelled then you’ll have to get heat under the truck to thaw the lines and filters. If you’re concerned and think you’ll be needing to start it when it’s cold I’d get some #1 or some antigel in the tanks and idle it for an hour or so to circulate it through the system.
  5. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    Seen on the old episode of Ice Road Truckers, they used and Heater blower under the carriage to warm the engine up after it was sitting outside. However, it was inside the shop. I think it should work if you leave it outside.
  6. SmallPackage
    5,777
    18,543
    Dec 20, 2019
    Marion Texas
    Milwaukee makes a nice M18 heat gun. That may be the way to go in an emergency.
  7. Big Road Skateboard
    7,091
    40,166
    May 2, 2021
    I've thawed out a bunch with a diesel heater ran off my generator. If there's not much wind, just open the hood and set it to where it's blowing mid engine, and angled back.
    About 20-30 minutes usually and you're GTG
  8. abyliks
    abyliks Road Train Member
    4,110
    9,665
    May 2, 2010
    ludlow MA
    Grab a couple cans/transfer tank and go get some kero from a local fuel guy,
  9. AModelCat
    164,566
    I love the diesel we get up here. It won't even cloud when its -30°C
  10. Long FLD
    12,845
    53,754
    Mar 4, 2015
    Best part about running up there. If they were calling for a cold snap I’d stop and top off at the card lock in Sparwood or the J in Nanton.
