fuel lines
Discussion in 'Freightliner Forum' started by scokat, Oct 23, 2016.
  1. scokat
    scokat Bobtail Member
    33
    20
    Oct 14, 2013
    Having an issue with fuel tanks, 96 classic with a Detroit. Truck is feeding off of passenger tank, but returning fuel to drivers tank. Any suggestions. No fuel shut off valve. should the fuel lines be replaced or just blow out. Seems like the pickup might be clogged on the drivers side, and the return on the passenger side. was working fine.
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Make sure your fuel tank vents are clean and not clogged. If one or both get clogged with junk it causes funny things to happen.
  4. scokat
    33
    20
    Oct 14, 2013
    actually on last trip we had to connect the fuel vents so the fuel would cross over to passenger side. it worked enough to get us home.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Did you look under cab on drivers side for pull rods that cut fuel off an on to each tank, the fuel dis. return valve is mounted on top of trans. follow lines till you find it and buy new not rebuilt one.
  6. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    So the fuel is not returning to passenger tank?
    They may be collapsing inside where you can't see what is happening. Remove, disconnect both return lines and see if both are flowing.
    Hard to do the same for the supply lines. You can pressurize your tanks with air to see if the fuel flows up the supply lines. I have checked mine that way.
    One of your "T" s could have blockage also.
    Good luck.
  7. scokat
    33
    20
    Oct 14, 2013
    ok, disconnected lines, blew them out, then reconnected and pressurized tanks, everything seems to be working
  8. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    + 1 for what Baha said !
  9. xsetra
    5,196
    7,146
    Aug 21, 2011
    Good to hear.
